Question about Simplex Kaba Ilco Unican 1000 keyless lock
Hi fix is this lock handed or is it reversable
Posted by kenhamilton_ on
Kelly
  • 3,740 Answers
Hi and wlecome to FixYa, I am Kelly The locks are preset left handed but can be changed to RH.
Download this manual
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_pkg_2280.pdf&Attachment=True
Go to page 14 of the manual and follow the steps.
If the link does not work for you then use this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13 and click on the MANUAL for your lock.
Thanks for choosing FixYa,
Kelly
Posted on Sep 22, 2011
Hi, Why does it feel as if the hand brake is up & the back wheels are locked when I try to reverse?
run the fault codes and look for a reverse servo /solenoid problem or a TCM fault
Nov 04, 2015 | Cars & Trucks
Electronic lock works the opposite way how do I reverse this
If it's on an airline reverse input/output, if it's electric you might have the polarities the wrong way round.you could try swapping connectors.This is not without risk.you may damage circuitry doing this.
Dec 03, 2014 | Locks & Locksmithing
My 1987 Nissan 300ZX does not shift into reverse. All other gears work fine. I was told I would have to remove the transmission to fix the problem. Tell me if that is the correct solution to fixing the...
HI there unfortunately that is the correct solution
the reverser gear fork or reve gear syncros
are both inside trans housing
You should sand trans out and all the gear checked
and replaced not just reverse gear ok
good lock
Jun 28, 2011 | Nissan 300ZX Cars & Trucks
The lock has reversed itself. I just replaced the batteries and now the door unlocks pressing the lock button and only locks when I put in the code.
Did you accidentally remove the jumper that determines the "handedness" of the lock?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Mar 18, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
The lock button UN-locks the unit, while the entry code LOCKS it. How do I program it to reverse?...
here's a link to the solution:
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do? First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Feb 11, 2011 | Weiser Lock Powerbolt 1000 Lock
I was changing the batteries. Now the bolt retracts when you push "lock" and Locks when you put the the code. How do I fix this reversal function problem?
Here is a link to the Frequently asked question page for your lock:
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Sep 03, 2010 | Weiser Lock Powerbolt 1000 Lock
Aside from the possibility of the unit "losing its marbles" the only thing I could think would be to reverse the handing by moving the jumper from Pins 1&2 to Pins 2&3 or vice versa... see what effect that has. And if still not working, see what effect it would have to move the jumper back to its original position.
I might also try letting it sit overnight without the batteries in it.
Jan 28, 2010 | Weiser Lock Powerbolt 1000 Lock
1993 camry le 6cly will not roll backwards. can jack up all wheels and all free. car will move forward bur locks up as in park when reversing.bye the way the service brakes and the hand brake are free.it...
It sounds like a problem with the reverse gear and you're probably going to have to have a transmission shop look at it,I'm assuming it locks when it's running and you shift into reverse.
Jun 22, 2009 | 1993 Toyota Camry V6
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
102 people viewed this question
Top Simplex Locks & Locksmithing Experts
JonSnell Electronic
JonSnell Electronic
Chris Walker
Chris Walker
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
