Question about HP OfficeJet 6110 All-In-One InkJet Printer
Como resolver error oxc4eb841a en impresora HP deskjet 3050 serie J610
Posted by tectronic199 on
Omar Javier Marsonet
    New Friend:
I have a problem, when I turn my Hp deskjet 3050 multifunction gives me an error code and not OXC4EB841A concerned
thanks
Posted on Oct 26, 2013
  • Omar Javier Marsonet
    Omar Javier Marsonet Oct 26, 2013
    How to solve Error oxc4eb841a in HP deskjet 3050
5 Related Answers
Anonymous
  • 100 Answers
SOURCE: rodillo roto .. como desarmo la impresora hp C5280
Pls take ur printer to the service center.
Posted on Mar 14, 2010
Anonymous
  • 119 Answers
SOURCE: What cartridge should i use for the HP Deskjet
Hi
I am sorry but 301 is not the right cartridge.
The cartridge that this printer uses is Hp 61 Black and Hp 61 Tricolor
Regards
Upvansh
Posted on Dec 26, 2010
seeker5211
Seeker5211
  • 1089 Answers
SOURCE: how do you get a
Press MENU and then 2.
Press < or > to set location then press 'check mark'.
Press 1 to confirm.
If this doesn't set the language, then you will have to do a NVRAM Init. Beware that all settings will be reset to factory default. So, make sure that you know how to enter the correct ones.
Turn off printer. Press and hold the * and 'check mark' while you turn on printer. Keep holding the buttons down until you see displayed "Permanent Storage Init" Release the buttons. Wait for it to ready.
Now when it is ready you can press < or > until the correct language appears. Then press "check mark" and press 1 to confirm.
Good Luck
Posted on Dec 29, 2010
Anonymous
  • 40 Answers
SOURCE: my HP Deskjet 3050 J610 series didnt come with a
Most HP printers will have a free software download from the hp website at www.hp.com. Just look for the downloads or support tabs, it will allow you to search by your printer model. Once downloaded, install the software then plug in the printer so the computer can find it.
Posted on Mar 07, 2011
hatnip
  • 85 Answers
SOURCE: I am trying to replace
Below is the link provided by HP Support for your issue...
Incompatible Ink Error
Posted on May 02, 2011
Need instructions on opening up printer and installing cartridges
Here is a link to a video from HP that will show and explain the procedure. Please note that although the model is slightly different the process is the same.
HP Deskjet 3050A J611 and 3050 J610 All in One Printer Series Replacing...
Oct 16, 2015 | HP Deskjet 3052A
Hp officejet j3600 error del cartucho
Saludos
Mi nombre es Jose, es un placer intentar ayudarle para ello le recomiendo que limpies los conectores y mires bien cual es el cartucho que tiene problemas, de todas maneras puedes mirar este post.
Como solucionar error en cartucho impresoras hp
Oct 31, 2012 | Office Equipment & Supplies
My HP Deskjet 3050 J610 series didnt come with a disk to install it how do i do it
Mar 07, 2011 | HP Office Equipment & Supplies
TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
Para empezar, quite el enchufe de la corrente como unos diez minutos
Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
1,214 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
