SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
SOURCE: SHARP AR 275 PROBLEM E1 15 ERROR AFTER SOLVING THE
U2-40 Content CRUM chip communication error
I have beenb to quite a few jobs with this error code. What it is, is toner someitmes gets spilt between the chip on the back of the toner cart what talks to the machine. Its quite a common problem, it's weird that the E1 code has come about because of this. Perhaps you can spy down the back of the machine with a torch and just see if the contacts are clean. other than this you may be able to just reset this problem.
To reset your error code >>
Simply press this combination of numbers on your photocopier.
#, INTERRUPT, CLEAR, INTERRUPT
At this point the screen will ask you to enter a sub code.
Simply Type in "14" and press "Copy"
Your machine will restart. If this code doesnt reset your issue. Enter service mode again, and try code "16" and press "Copy"
Just for your info as well, this is the service manual meaning for your error.
E1-15 Content IMC board Page Memory error
Testimonial: "thanks i have given it a try but the machine try run but return back E1_15 code error then brings out F9_08 return back to E1_15 code when powere on"
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
SOURCE: SHARP AR M317 ERROR U2-40
That is a CRUM chip communication problem. Crums are on Drum units. Toner cartridges and Fusers.
One may have simply expierd, may have failed.
- Toner supply abnormality caused by
installation of unpacked toner cartridge
