Please login to router page by 192.168.1.1 enter user name = blank and password = admin
Once you click on the wireless tab>wireless security
Under this you can check the wireless key.
please follow the link.
Wireless Security
SOURCE: Connecting issues with wireless mode on WRT54G2
You may set Wireless security of the router to WPA Personal instead. Since it is the supported wireless security of your laptop. If the router is set to WEP then WEP must be set in the laptop as well. But if WEP is not supported by the laptop anymore, then might as well, set WPA Personal to the router.
Hope this helps!
SOURCE: want to ask security key when connecting wrt54g2
you can choose a automatic ID to connect to the internet
SOURCE: Forgot my Network name (SSID) & or WEP key or
hi
go to following link you will find your solution for wireless issue
http://compnetworking.about.com/cs/wirelessproducts/qt/changessid.htm
SOURCE: router wrt54g2 wont connect to my ho laptop asks
You have set up the security on the router itself so that nobody can steal your signal. When you did this you made up your own key/pass phrase. If you go back into the setup screen for the router you can look under the wireless tab then click on wireless security. Depending on what security you set up be it WPA Personal, WPA Enterprise, WPA2 Personal, WPA2 Enterprise or WEP it will show the shared key that you made up. You must enter this key in on your laptop EXACTLY how it is typed in the box in the routers information page.
SOURCE: Trying to install new wireless adapter on guest
Press the reset button on the router, and hold that like about 20 seconds.
That will return all factory settings.
ADSL Modem Settings to Wrt54g2 Router
Basic Wireless Settings
Wrt54g2 wireless security
Wrt54g2 firewall settings
