Philips 27PT5445 27" TV Logo
Question about Philips 27PT5445 27" TV
I have a Philips 4:3 size TV that has the subtitles locked on. There is no remove for the TV in the house, but we do have a Charter Universal Remote hooked up to it. CC is already turned off on the cable box so I know that is not the problem. Pressing PIP on/off does not do anything. How can I turn them off?
Posted by frasergrove on
5 Related Answers
Gigatech
Rafael Ortiz
  • 259 Answers
SOURCE: Philips PM3S - 3-Device Universal Remote Control
Here is your product manual:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000053128.pdf
It includes the codes2.gif for your remote. :}
If you dont see your product on the code2.gif list try a code search. If this fails your remote might not support your device.
Posted on Dec 17, 2007
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: philips universal remote code for direct tv.
I have a code table for you, you may try this if its different than yours. Here is the direct link (You need Adobe Reader to open it)
Good Luck
Posted on Dec 29, 2007
Anonymous
  • 2071 Answers
SOURCE: philips activation code for a remote control
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 22, 2008
Anonymous
  • 7 Answers
SOURCE: Philips Universal Remote PM435S reprogramming
I have the same tv and remote that you do. I went on Philips website and they have instruction manuals and the code lists. You can also press and hold the 'CODE SEARCH' button until the light stays on. Then press 'TV' button. Make sure your TV is on and press Channel Up button until the channel changes on your TV. If you go too far, press the Channel Down button until it changes again. Then press the Mute button to store the code. Good Luck!!
Posted on Mar 29, 2009
the q guy
Tony Walker
  • 393 Answers
SOURCE: Universal Remote used to control Digital converter box
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on Jun 12, 2009
How to program a AVOL tv to a universal remote not in book
AVOL 4 digit codes:
2735 1820 3382 2051 2397 3118
AVOL 5 digit codes:
13118 13382 13479 12735 12051 12397 12278 11531
2helpful
I can not turn off the closed captioning on my philips tv , i do not have the original remote to the tv but my cable remote works as a universal remote, please help me the subtitles are driving me crazy !...
I have direct tv, and had the same problem. After an hour on the phone with the worthless tech, I gave up. Finally I figured it out. First of all do you have closed caption problems or is it "subtitles". mine turned out to be direct tv subtitles, not closed caption. I hit the yellow button on the direct tv remote, and presto. Subtitles was set to the on position. changed it to off, and what do you know. fixed.
5helpful
RCA L40FHD41 Remote key
The only way I could get it to work is use Philips Universal remote SRU4208WM/17. You must use the learning code.
Can't turn subtitles off
Hmm... have you tried ontop of the remote where it has "tv" vcr" sat" etc...hit tv first then try the menu?and do you have satelite by any chance? because something similar happened to me when i had my old tv put upstairs and hooked up, the remote for it did not work so i had a universal and the tv was on "video 1" input the whole time and the universal remote didn not convert it back to tv so what i had to do was hook up the reciever to the "video 1" port instead of the "tv" input in the back...i hope you get it cause i know it can be a pain in the A$$
111helpful
5answers
Need Philips Universal Remote Codes for a Sanyo TV
Hi Pamr
Try the Phillips website >HERE< which links to their Universal Remote support centre. Unfortunately you haven't given the details of your actual remote but you should be able to find it and download a manual or email them direct.
Sanyo TVs use all these codes:
0506, 0311, 0612, 0002,
0428, 0802, 0412, 0619,
0208, 0157, 0292, 0036,
0011, 0370, 0072, 0216,
0217, 0104, 0045, 0009,
0163, 0037,
Sorry there are so many, but one should work.
Best wishes...
STUMPED
KUJO,
This should help... Charter doesn't make a remote and millenium 4 is like saying cotton swab, which doesn't tell me who actually makes it like Q'Tip... But this should get you in the right direction. http://www.remotecodelist.com/remotes/
Bill
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
