Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I bought this washer second hand and it worked in the guys house buit when i got it home problem began. When the washer goes to the spin cycle it starts off ok and then starts banging and banging. louder and louder. The springs seem fine but what other things should i be looking at that could have broken in transit.
Posted by snow4lisa2 on
Robert Smith
    Sergeant:
  • Whirlpool Expert
  • 243 Answers
Make sure that the tub has full movement and bounces back to the center. if it doesnt its gotta be the springs
Posted on Sep 22, 2011
Washer wont operate a spin cycle
What is the model number of your unit?
Nov 24, 2012 | Washing Machines
LOUD!!! Spin cycle
Whats even more mundane ,this plays havoc on the electronics and specifically the expensive control board.Opt for extended warranty coverages!
Aug 15, 2009 | LG WM2455 Front Load Washer
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hey sorry about the messages but
ok their,those screws you see did screw into a plastic housing[lid switch] that now has cracked and the screws are bairly hanging on to the switch.now here goes...unplug you washer,and reach your hand in there,break or pull that switch up where you can work on it.you then can tape the lever in the run position[down]now thats if its not broken[the housing]now if you have done this your washer will not !!!!!!!!!!!! stop in spin cycle when you lift the lid.soooooooo if you or a child or wife put your arm in there while it was spinning[danger][will robinson] their have be cases of persons getting their arms torn off.sooooooooo,get a new switch and you dont have to worry.if you have small children they are curious and will play with the washer when you are not looking.i did at my home.anyway im there if need more help,email........God bless ,tom
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Washer Froze, Spin Cycle Sounds like Jet Engine
when it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Dec 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE PROFILE WASHER M# WPGT9350COPL
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
let me know what it tell you I can help...
Sep 01, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
51 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
