M-Audio is notorious for hardware related problems, mainly the USB ports. After awhile the ports wear and fail to hold the tight connection needed to keep the board fully functional. But I've seen the same problem with new boards too because of bad soldering.
If it's new then don't bother wasting time trying to figure it out. Just exchange it and save yourself the headaches. You may even want to look another board. If your partial to M-Audio then the Axiom is much better than the Oxygen. Either way, take advantage of the ability to exchange while you can, cause once that's over M-Audio will give you the finger.
Your PMP what? Is this a Behringer?... and if so what model?... If it won't power up, for goodness sakes do NOT replace a blown fuse as additional damage usually results. Get it serviced... if under warranty, then exercise the warranty. If it is a BEhringer, then also read my tip on Fixya tips regarding PMP mixers and a hazard of using 1/4 inch plug speaker cables or adapters.
Could be the level from your guitar is too high OR low. Too low the tuner can't get reliable signal... Too high and the tuner will see harmics of the strings. Make sure you set onboard shape or EQ's flat. You CANNOT tune while playing CHORDS... A single note at a time please...
typically with these if you get a no read disk on disks you have once before known to work in the unit then you probolly need a new drive. You may try to use different types of cd's ( expecially if burnt ) owners manual might have a preferred brand in it.
That's the thing with today's electronic and why warranty length is so important. Where did you buy your keyboard? It's strange that they won't fix it if it's still under warranty. My Casio CTK-2100 came with 1 year free service and they fix one key that stopped function in few days. I'm pretty sure Yamaha has the same warranty length. You sometimes have to bevery persistent with them though...
Hallo! This is caused by the laser fault. First unplug the cord, high voltage!!! Disassemble the device, look under the cd place you will see a little lense. Clean it VERY DELICATE with a piece of cottonwool with alcohol, can clean it twice with alcohol and then with a dry one. If doesn't help, then need to replace the laser reader system with a new one, it's that where the lense is placed, it must have on it an badge with the serial number, you can search it by that number/code.
Are you using battery or AC adapter for power?
Most pedals won't allow you to use both. Check that there is no battery installed if you're going to plug it in. If you are using a battery, Some pedals won't light an LED on battery power.
If problem persists, your pedal may be DOA
