Question about Sony NWZE345 MP3 Player
PC no longer recognizes my NWZ-e345 MP3 player.
Posted by loreo88 on
Curtis Sewell
  • Sony Master
  • 7,482 Answers
Hi loreo88...
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
Posted on Sep 21, 2011
Mp3 8GB NWZ-E343/E344/E345
How do I download music from CDs as well as from the network?
6helpful
2answers
My nwz e345 is stuck on every music has it moment screen then it freeze. then when i plug it to the usb it say device driver software was not successfully installed
Hey, I had the same problem, I found the solution!
First, reset your Walkman via a pointy object and the hole in the back. Then, replace the USB cord you use to charge and add music (it's a quite common cord for cameras and can be store bought).
This solved it for me!
PC does not recognize Sony NWZ-E436FR!
try it on another pc
it will work
and if it works then you just need to format your pc's
c drive and reinstall the os
7helpful
Media Manager for Walkman 1.2 does not recognize Sony NWZ-S615F
look up here: http://www.sony.com.my/support/faq/1169186/product/nwz-e435f/print
5helpful
3answers
Sony Walkman NWZ-S615F problem detecting and syncronizing
I had the same problem. One day my Mp3 started acting weird and said it was not recognizing the files and that i needed to re download them. Try plugging it up to your computer while its charging and hit the power off. Then reset your mp3 with the button at the bottom and it should recognize it.
Sony NWZE345 MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
