Question about Clarks UnDeniable Shoes
I purchased several pairs of clarks rise sandels and was caught in the rain one day. The sandels have a terrible odor now since they got wet. It is very offensive and I would like to return them. I pruchased them at a local Boscovs in Moorestown,NJ. What would you suggest and have you had any problems like this before. I know they were manufactured in China. Jeanne Chonus, 609-914-0860, [email protected]
Posted by Jeanne Chonus on
Jim Pattison
    Master:
  • 1,004 Answers
I don't have clarks, but shoes do this if wet and they dont get dried out right. Get some sneaker sweetener at a shoe repair shop and it will be better. ozone treatment is anotherpossibility.
Posted on May 11, 2014
Sending a pair of shoes back to clarks
Clarks online is confident that you will be happy with your purchase. If for any reason this is not the case, we offer FREE RETURNS for items over $60 within 28 days of the order date. Clarks will not take responsibility for returned items not received if registered post is not used. We have 4 conditions of return for change of mind, item(s) must be returned:
    -Within 28 days of order date
    -Item must be unworn with original tags still attached
    -Items must be returned in original shoebox
    -Postage is non-refundable
Mar 14, 2017 | Clarks Clothing Accessories
I got caught in the rain yesterday my air filter get wet and I let everything dry not now its starving for air and won't go over 20 miles an hour
The fibers in a paper type air filter swell up when wet. Like spilling water on a sheet of paper that does not return to its original shape when dried.
You will need to purchase a new air filter element.
Sep 08, 2015 | Cars & Trucks
1170XL Plus Pride wheel chair problems, VSI shows full charge, and gets hot after a few hours
Medicare should be able to help you locate a service center. The controller has some electronics that may have been damaged by the rain. It needs to be tested for sure.
Jul 29, 2014 | Pride Health & Beauty
Could you repair a pair of Cobbie Cuddlers shoes?
It is possible for a shoe repair shop to repair them. The one who you saw suggested a solution of taking them back. Did you not want to do that?
Jul 11, 2014 | Clothing Accessories
Got caught in the rain
The saw is probably OK but the battery is toast. Cordless batteries absolutely do not like to get wet. None of the manufacturers will warranty a battery that got wet. Sorry. Buy a new battery.
Mar 02, 2014 | Porter Cable Portercable Pc186cs 18v...
Whirlpool calypso washer smells how to get rid of ordor
Removes odor causing residue in front loading (HE) washers. Keeps your machine fresh and clean. Package includes 3 tablets. For front load washers only.
Here is what you need.
Oct 18, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
2when I open refrigerator door there is a terrible odor from the refrigerator. Have removed anything in the refrigerator that could possibly be smelling. got any ideas?
Have you removed the bins and cleaned under them. Sometimes the overflows and drips accumulate there.
It the refrigerator is clean, then baking soda usually helps with absorbing the odor.
But if you still have odor being produced and the unit is clean, you need to look further. If it is a chemical smell you might want to roll the unit out and check to make sure that there isn't a creamy looking liquid on the floor, which COULD be freon.
But the most likely item is that you have some bacteria growing in the drain line that is producing the odor. Suggest you mix a 50/50 mix of bleach and water and pour that down the drain to kill the bacteria. Do that several times over a day or two and see if the odor goes away.
Jun 12, 2011 | Kenmore 53642 / 53644 Side by Side...
Loses power when it rains or wet outside
The is the coil pack itself? Is its surface clean?
Try reducing spark plug gap, because then the voltage does not have to rise as high.
Jun 02, 2010 | 1988 Honda Accord 4 Door
Missfires when wet .usually garaged but left in rain overnight next day ran terrible ok later when dried out
its possible theht leads or plug caps are tracking and your loosing the spark causing slight missfiring replace ht leads and caps and see if that solves the problem
Nov 11, 2009 | 2003 Triumph Speedmaster
Clarks UnDeniable Shoes Logo
79 people viewed this question
Top Clarks Clothing Accessories Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Bill Boyd
Are you a Clarks Clothing Accessory Expert? Answer questions, earn points and help others
