Question about Vizio L32 32 in. LCD HDTV
Start by checking the power at the mains terminal, then check the continuity of the power input cable. if its healthy then confirm that all fuse in the cable plug is ok.remove the cover and check on the switch mode power supply.conduct a visual inspection to acertain any blown component like the fuse, swollen filter capacitor, the burnt resistors and diodes. if they do not seem to appear phisically burnt then conduct a meeasuring test with a multimeter.
replace any faulty component and test the television by opening the power input fuse and connecting a 100w bulb in series and feed in the power. if the tv oscillates and the bulb lights up then gets dim gradually then the tv is working hence you can now remove the series test bulb and place back the fuse and connect all the cables in place and feed in the power and you see your tv lighting up
Posted on Sep 21, 2011
Apr 02, 2014 | RCA 46 46LA45RQ LCD TV
Apr 04, 2012 | Sanyo DP50747 50 in. Plasma TV
Sep 23, 2011 | LG Televison & Video
Sep 12, 2011 | Bush Televison & Video
Feb 08, 2011 | Sony KDF-E55A20 55 in. LCD Television
Sep 24, 2010 | Televison & Video
Dec 31, 2009 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
Mar 17, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Jun 24, 2008 | Hitachi Televison & Video
Nov 25, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
89 people viewed this question
