Check the incoming power with a tester and if ok then check the plug fuse and if burnt replace and if ok proceed to open the tv cover and check the cable continuityand check the fuse in the power supply region if blown, check other components inthe power supply area and replace the faulty ones if any then open the fuse in the power supply and connect a 100w test lamp to see if there is a short circuit. if the bulb lights up and gets dim gradually you ca now remove the lamp and put backthe fuse and test again
however, your tv problem could be solved by simply replacing a burnt fuse but its always advisable to verify the cause of the blown fuse
Posted on Sep 21, 2011
Jan 26, 2016 | Televison & Video
Aug 05, 2014 | Protron PLTV-37 37 in. LCD Television
Aug 01, 2012 | Mitsubishi WS-65819 TV
Mar 21, 2011 | Mitsubishi Televison & Video
Aug 26, 2010 | Vizio VP322 32 in. Plasma TV
May 23, 2010 | Akai LCT3701AD 37 in. LCD Television
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Jul 04, 2009 | ViewSonic N3735W 37 in. LCD TV
Apr 07, 2008 | LG 42PC5D Television
Apr 03, 2007 | Toshiba 50A60 50" Rear Projection...
Jan 05, 2021 | Sanyo Televison & Video
221 people viewed this question
