Question about RCA F36450 36" TV
Power button turns on and off but no picture or sound.Describe your F36450 36" TV Problem
Posted by wschmid3 on
5 Related Answers
Anonymous
  • 119 Answers
SOURCE: TV will not turn on when power button is pushed.
check the main fuse in the tv. test it with a multimeter, not visually. if its the thermistor that blew the fuse, it is very difficult to see the break in the wire. replace if blown. if unit blown fuse again withing a couple of weeks replace the thermistor in the degausing circuit. good luck.
Posted on Jan 09, 2007
Vista Electronics
  • 1694 Answers
SOURCE: 36" RCA TV Wont power up
Best suggestion is IHVT,also known as flyback transformer.Thomson products well-known for xformer troubles. (GE,RCA & Proscan)
Posted on Oct 04, 2007
Anonymous
  • 17 Answers
SOURCE: no picture or sound
Classic power supply or horizontal output problem. Take it to a servicer.
Posted on Oct 18, 2007
Vista Electronics
  • 1694 Answers
SOURCE: won't turn on
Most common fix is replace flyback transformer ASTI # 2078
and horiz out xistor RCA # 237470.....................T.
Posted on Mar 03, 2008
Anonymous
SOURCE: my 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
my 36" rca green light blinks 3 times, no picture or sound
Posted on Jun 02, 2009
Loud buzzing sound from tv with no picture
It sounds as though your SMPS is seriously faulty and normally one can buy a kit to correct the problem if you are a TV engineer, however there could also be many other reason for the condition that you describe its almost impossible to guess correctly, it really needs a qualified engineer to assess the problem along with he or she having the set with them.
Sep 04, 2016 | Samsung PN42C450 42 in. TV
Dynex dx-40L261A12 won't turn on. Red power light is on, but no sound from speakers and no picture. Remote power button and power button on tv doesn't turn the tv on.
In this case, the symptoms you describe is a faulty inverter board. The TV will or should flash "PLEASE WAIT" and then you have a black screen no audio. Find Shop Jimmy on line. Enter your TV model number. You will find an inverter board for $24.95 plus $9.50 shipping. When you remove the back cover of the TV, look to the left. You will see a long vertical board...this is what you will replace. Thanks for asking, Matt of Martins TV Repair.
Oct 15, 2013 | Dynex DX-L42-10A 42 in. LCD TV
Thanks for your reply for my Toshiba 65H80 question...."as watching TV (Bears/Packers) and saw on the screen what I can only describe as a small "explosion"......or flash of light and then...
Hi. I believe you have been given some erroneous information. The items that are faulty are actually the capacitors. They are designed to last about 30 years if they are of good quality, however from 1998 until around June of 2005 Taiwan was flooding the market with cheap low quality capacitors, whiah are lasting about 1/3 as long. Thes are unfortunately not cheap to replace, as they are called low ESR capacitors. They can, counting the cost to have them replaced, be more expense than buying a brand new TV. If you really love your tv and just don't wish to depart with it yet, you can take it to Best Buy or Fry's, they both have specially trained techs to repair this exact situation.
Jan 24, 2011 | Televison & Video
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
RCA F36450 36" TV Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
