Uniden BC796D Base Scanner Logo
Posted on Sep 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Comunication error with 796d and computer.there's no serial port on my computer, so im using a rs-232 to usb. dosen't matter what usb port i use on computer, it still does not work. im using the software that came with the scanner.
Iron
Level 3:
  • Master 3,018 Answers
  • Posted on Sep 21, 2011
Iron
Master
Level 3:
Answers
3018
Questions
Helped
1669186
Points
10301
  • Hi, I can help.
  • This happens a lot to people just setting up a scanner like this. Try these suggestions, I think you'll be up and running in no time.
  • You have to make sure the BAUD rate is set and make sure your PC control is turned on in your scanner. A BAUD is the rate per second data is sent.. A BAUD rate of 38400 (or what ever BAUD the software is at). I think parts 3,4 and 5 in the your scanner menu cover this. If you have the FIFO buffer set then remove it from your settings > control panel > comm ports. You will get the best results if you have that software read the bank before writing to it. Relabel your comm port settings if you need to as well ie. port 1, port 2 etc.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa,
Regards, Tony
Need drivers for PCI-E expresscard 1/0 adapter
Go to www.drivers-download.com and search for DL-0254103 from "Drivers Search". Or you can use an alternate site: www.prolific.com.tw Use this path: Download >> USB to Port Controllers I/O >> PL-2303 Software and Drivers.
tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 • Computers & Internet
1helpful
I have APIOTEK EC-0008 serial express port card RS 232 it is not getting installed on my dell windows XP enviornment what is the reason
have you installed drivers for the card, as windows might know what it is but it wont be able to use it till the drivers are installed click below onto what version of windows you have and download the drivers
EC-0008
Windows 98/M2/2000/XP/2003
Windows Vista 32/64bit
MAC 8/9/OSX
Linux RedHat 7.3/8.0/9.0
1helpful
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
1helpful
Tried to install USB to Serial adapter but get a message "Prolific USB-to-Serial Bridge (com3) Failed
To change the COM port number assigned to a USB to RS-232 Serial Adapter follow the steps below:
  1. Open the Windows Device Manager.
  2. Right click on the COM port you want to change.
  3. Left click on Properties.
  4. Click on the Port Settings tab.
  5. Click on the Advanced... button.
  6. Use the drop down list to select the COM port number you want to use.
  7. Click OK.
  8. Click on OK again and close Device Manager
It can work with adapter usb i don't have ps2 port in my computer
The LS 4000i is available with several different interfaces.
LS4004i - RS-232/Serial interface
LS4006i - Keyboard Wedge interface
LS4007i - USB interface
2helpful
3answers
NCR 7875 Scanner/Scale Communication problem with PC
You need another cable (the metrologic cable doesnt work with the same configuration) and set the button in the interface card to rs-232 and program the scanner-scale with the programing tags.
Dec 04, 2008 • NCR 7875
2answers
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Rs 232
try unplugging and uninstalling the rs232 and reboot then turn off then plug the cable back in and turn on. it should detect and install.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
