SOURCE: replacing door chute on kenmore refrigerator 57562792
first of all unplug the refrig.
look at the bottom of the disp cover and you will find 2 slots for you to slide in a flat tip screw driver. carefully pry the bottom of the cover loose 1 side at a time.once this is loose, either remove the 2 screws that hold the switch housing in place or release the clips ( depends exactly onwhich model you as to wether there are clips or screws) once this is free remove the plastic funnel, by this point you should see how the chute door removes.
a few notes the disp cover can be hard to remove but it will come loose also reinstalling just hit it firmly over each clip witht he palm of your hand.
good luck..
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
SOURCE: can't get the refrigerator through the door ; how to remove handl
When I brought my side by side home,I had to remove both doors. I also had to remove the entry door AS WELL as the door center jamb!! Removing the refridgerator doors is really not a major task!
SOURCE: I need new refrigerator door handles?
Go any appliance parts website and look up your model, you should be able to order them online
HOW TO REMOVE DOOR
HANDLES (LFX25960
To move refrigerator through a house door, it may
be necessary to remove the refrigerator door handles.
1. Removing Refrigerator
Handle
Grasp the handle tightly with
both hands and slide the handle up (this may require some force).
The keyhole slots on the back of
the handle allow the handle to separate from the mounting screws.
CAUTION:The handle could be damaged if
you hit it with a hammer while removing or attaching.
CAUTION:When you assemble or disassemble
handle, you must push or pull with reasonable force.
2. Removing
Freezer Drawer Handle
Press the handle
against door first.
Grasp the handle
tightly with both hands and slide the handle to right (this may require some force).
the back of the handle allow the handle to separate from the mounting screws.
If you need help:
http://us.lge.com/download/product/file/1000003873/LFX25960_LFX21960owners.pdf
