Question about KitchenAid Kitchen Ranges
KitchenAid range ProLine series kesv908 and ykesv908 Oven desplay comes up with err button stuck F2EO
Posted by barbsofarell on
Reynaldo Labaguis Jr.
    Genius:
  • 1,157 Answers
Hi barbsofarell,
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Hope it helps.
Thank you for using FixYa.
Posted on Sep 22, 2011
Display says err button stuck F2EO
Very vague does this oven have a keypad and a separate control or all in one if separate change the keypad
Apr 03, 2015 | Kitchen Ranges
Err codeF2EO Stuck Key onContol panel touch pad
Hi have a nice day
F2 - E0 Oven temp too high
1. Test operation of door lock on self-clean
2. Test relay contact operation
3. High resistance in oven temperature sensor
Guruood Luck !!!!!!
Feb 16, 2008 | Kitchen Ranges
Error code F2EO
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
GENE
Nov 06, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven preoblem kitchenaid ykers807sp "err f2e1 stuck/shorted key " showing
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
Jul 17, 2009 | KitchenAid Architect Series KEBC107KSS...
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Error
f2eo stuck key sign
Mar 26, 2008 | KitchenAid Kitchen Ranges
Kitchen Aid Gas Range, Model KGR 1801
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) theres the bad news its reading a stuck key pad. replace the control..
there may be a good side and that is depending on age of machine they usually come with a 5 yr part warr on their electrical components, in which case youd only pay service and labor to install it
Mar 20, 2008 | Kitchen Ranges
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Oven not working
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Sep 05, 2007 | KitchenAid KESC300 Electric Kitchen Range
Kitchen Ranges Logo
375 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
wp4eld1
Level 1 Expert
gbob59
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
