Question about Cisco 7940 IP Phone
I'm experiencing a problem with cisco 7941 IP phone. here is the current condition of the phone: it has no dial tone, the programmable button is alternately blinking, the headset button has a steady light. and I cannot see anything on the display? I tried to reset the device but I think it is not responding.
Posted by john_will484 on
Imran Mohamed
  • 72 Answers
Can you explain me how is your phone connect to internet.
best on your Question its seems to me you cant hear a dial tone because of following one or more factors might apply
  1. you must log into the Extension Mobility service
  2. you must enter a client matter code (CMC) or forced authorization code (FAC) after dialing a number
  3. your phone has time -of-day restrictions that prevent you from using some features during certain hours of the day
Posted on Oct 11, 2011
I need to modify the settings of my cisco ip phone 7941
Complete these steps:
  1. Unplug the power cable from the phone, and then plug in the cable again.
  2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. ...
  3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
Aug 04, 2015 | Cisco 7941G-GE IP Phone
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
Why can't I connect my corporate Cisco IP Phone 7941 to a switch? I can connect a switch to Cisco phone switch and connect multiple devices. But the phone will only work when connected directly to the wall...
Connecting a hub or switch to the "PC" port on the back of the phone is not a recommended best practice by Cisco as the IP phone does not support spanning tree protocol.
Sep 28, 2010 | Cisco 7940 IP Phone
When I plug the 7941 cisco phone up to our network on a POE switch, it responds with the message "Ethernet Disconnected", but when we plug another Cisco 7941 phone to the same line it works perfectly... We...
I would check your duplex settings. Often, if you hard code the duplex settings or have a mis-match; one end may not talk properly. Also, have you tested the wiring? Do you know the ethernet is okay for sure? TechRx, Inc. - techrxgb.com
May 12, 2010 | Cisco 7941G-GE IP Phone
CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Jan 07, 2010 | Cisco 7941G IP Phone
CISCO 7941 IP PHONE disconnect you out after certain time
Unfortunately this is a very common problem with Cisco's IP Phones. It can be caused by either a faulty hookswitch or a damaged jack. Both of these problems can be remedied by contacting IdacomUSA.
Apr 06, 2009 | Cisco 7941G-GE IP Phone
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
363 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
