Question about MA Audio HK802SX Car Audio Amplifier
MY AMPLIFIER ON THE BIPOLAR JUNCTION TRANSISTOR CAUGHT ON FIRE WHILE I WAS PLAYING IS IT REPAIRABLE OR REPLACEABLE?
Posted by joeynmayra07 on
Cassette_guy
    New Friend:
  • 61 Answers
Yes it depend on how much damage is on the system. What you need to do is to identify the transistor model and look for replacement parts.
Posted on Sep 28, 2011
3055 transistor short
How do you know it is shorted. What is the full part number, that number is on transistors, MOSFETS and a few other things.
Jan 04, 2014 | Crown CE1000 2-Channel Amplifier
Name three classes of transistors
Among others, bipolar junction (BPT), field-effect (FET), and inverted T field-effect (ITFET). See http://en.wikipedia.org/wiki/Transistor#Types
Aug 07, 2013 | Car Audio & Video
800a4 stays in protect mode
Generally thats a sign of a shorted output device, either a bipolar transistor or mosfet. Also ground faults can trigger a protect light.
Feb 03, 2013 | Rockford Fosgate Punch 800a4 Car Audio...
Transistor source and price
rockford fosgate use hexfets.they are made by international rectifier and are available from toronto. they are n and p channel devices.they are not bipolar transistors...
Jun 16, 2009 | Rockford Fosgate Punch 401S Car Audio...
Trying to find the right FET to replace burnt up ones with
hafler use international rectifier hexfets. there is alot of confusion what constitutes a mosfet amplifier.
if the outputs are mosfets instead of bipolar transistors, it is a mosfet amp.
some designs are using mosfets to drive the switch mode power supply,but use bipolar output transistors.that is not a true mosfet amp.
you need to go to an electronic supplier for the repair industry.
or the manufacturers warranty depot,who will be able to order them.mosfets are very high current devices,you have to ask ...why did they fail. if they are the switch mode drivers,there is bad capacitors in that circuit
May 23, 2009 | MTX Thunder 5-Channel Amplifier 895 Car...
Aplifier Not Working
Sounds like there is a shorted output transistor or two in your amp. Unless you have a DMM that can measure transistor junctions, you probably can't fix this yourself.
Sep 03, 2008 | Onkyo Audio Players & Recorders
AudioBahn A2301Q
On the following page, go to the section labeled 'Checking Bipolar Transistors'. Under the two images, you will find a link to a form that will allow you to enter all of the values with the various lead configurations. Follow the instructions and send me the zipped file with the images. There's a link for my email address. Testing results are more definitive when the transistors are out of the board but initial testing in the board is reasonably reliable.
Checking Transistors
Jun 14, 2008 | AudioBahn A2301Q Car Audio Amplifier
Pioneer m-770 will not turn on
you probably have a short in the circuit some where. you need to replace the transistor and look at all the solder joints to make sure there not damaged or cracked. i have the same amplifier and i replaced the fuse several times and it blew every time up until the last time when the 4 of the power output transistors blew. what ever you do do not try and power it on till you do all the things i told you or you will have sparks and fire. my mistake cost me my amplifier. but might help you get yours repaired
Dec 24, 2007 | Audio Players & Recorders
Mtx81000d 3rd chance
The original output transistors (SSP45N20A - if I'm not mistaken) for this amplifier are very difficult to find and there are virtually no substitutes that will work without extensive modification. Many techs try to use the SSP45N20B but they don't work reliably.
If you do find replacements, expect to pay $15 or more each. It's possible that there are other problems also. For example, the over-current protection may not be working properly. When it's working properly, it will generally trip when the output transistors fail (which prevents damage to the subs).
This is an old design. The newer amps will be more reliable and will generally offer better protection for the speakers.
Nov 19, 2007 | MTX Thunder 81000D Car Audio Amplifier
MA Audio HK802SX Car Audio Amplifier Logo
Top MA Audio Car Audio & Video Experts
Fahr Quad
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
