SOURCE: Error: ink absorber full. Does not print or scan. Ink cartridge doesn't move.
how to solve problem E27?
SOURCE: how do i send a fax with my cannon MX310 what are the steps?
Plug a phone line into the LINE port place original face up on the feeder dial the fax number press START (fax)
SOURCE: I have installed my Canon MX860 printer on OS X
see this link how to connect wireless printer
SOURCE: Canon PIXMA MP130 printing blank pages & cartridge jammed message
Hi You can Try
Error Code 5100
Yes see lots of this errors
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
SOURCE: When trying to send a
Hey! If the take out the cover that's covering the receiving paper,Look in there and u will see a black lever with a green sticker on it!Make sure its clipped into place by pushing it upwards un till you hear the click sound!Then press ok!!Enjoy! Good Luck!
