You might have installed the wrong driver for your computer's operating system (OS) version. Uninstall the driver then check the OS version (32-bit or 64-bit). Right-click on My Computer (Computer) then selectProperties.
The system information of your computer will open then look for the system type.
Once the system type is determined, reinsert the driver CD then right-click on the CD-ROM drive and sI have installed Crosley CR5503A - jan_mczeal_1.jpgbr />
The contents of the driver CD are listed. Open Driver folder then select and open the driver folder for the OS version (32-bit or 64-bit) of your computer. Right-click on the setup.exe (setI have installed Crosley CR5503A - jan_mczeal_2.jpglect Run as administrator.
The driver will install until a notice is shown that the scanner has been install successfully.
You can address the "Acquire Source Failed..Restart DSM" message by right-clickiI have installed Crosley CR5503A - jan_mczeal_3.jpgr button at the status bar then selecting Maximize.
I have installed Crosley CR5503A - jan_mczeal_4.jpgindow will open. Click File and select and click Select Source.
I have installed Crosley CR5503A - jan_mczeal_5.jpg />Highlight (Click) the name of the correct scanner installed then click the Select button.
You should now be able to use the scanner.
