SOURCE: samsung shr 1040 4 channel dvr
I think I can offer a solution. The unit is set up from the factory with television input enabled. You'll need VGA input enabled. Hook it up to a TV; go to setup in the menu and enable VGA. Then you'll be able to use your monitor.
SOURCE: SHR-1040 Samsung DVR
It does the same thing to me....Can you imagine sitting there viewing the whole hard drive just to see what happen 39 minutes ago. This Samsung DVR is stink.....believe me ...Every problem I read on here,,Im have the same..
SOURCE: I forgot my password and I cannot do anything.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
SOURCE: I HAVE A SAMSUNG DVR SHR 2040 AND WAN TO VIEW FROM
connect the iphone to the USB port of the DVR through the iphons data cable.just connect and enjy it.
