Question about Ovens
Hi, I am thinking about buying a logik lbfanx10 oven but I understand it has to be hard wired. My old oven is simply fitted with a 13amp plug and it just plugs into a socket. As I do not know the power consumption of the new oven I do not know if I can just fit a cable and plug it into a 13 amp socket.. Can you advise? Many thanks Mr E.Emmerson
Posted by eddieemmerso on
Ernest
    Master:
  • 434 Answers
The following website installation and user manual indicates a current value of 13-15 Amperes. You may have upgrade the wiring and the plug.
https://www.manualslib.com/manual/935752/Logik-Lbfanw10.html?page=11#manual Specification Model LBFANX10
Rated Voltage 230 - 240 V
Rated Frequency 50 Hz
Power 3200 - 3500 W
Current 13 - 15 A
Top Element 1200 W
Bottom Element 1100 W
Posted on Oct 10, 2017
4 Related Answers
Anonymous
SOURCE: Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Posted on Mar 05, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: oven connection
I have tried to locate electrical information on your oven from here in the USA. I was not able to locate the electrical requirements for your Zanussi ZOD 330X. If it is typical voltage for ovens like ours in the USA I would say no and that the power should be 240 volts and 50 ampere breaker. But to be sure you should locate a local supplier for your model and ask them first. This will prevent any incorrect answers from someone that is not familiar with your local requirements. Thank You, Sea Breeze
Posted on Mar 25, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: My Neff U1661 has packed
It should fit without any problem most oven housings will accomadate most ovens, those in production now, and those made 10 or more years ago.
Posted on Nov 17, 2010
FitzOriginal
Chris Hall
  • 842 Answers
SOURCE: Have just purchased a hotpoint
Is this unit new?? Are you in the EU (EU regulations say appliances MUST be fitted with a plug) If it IS new, I would be talking to the supplier!
However, to address your question If it has a standard 3 core cable fitted, then it almost certainly should have a plug on it!
To reassure yourself, just use the simple formula of Watts divided by volts = amps
I'm presuming that you are in the UK (240 volt supply) and the oven is under 3KW (3000 watts)
This being the case 3000 watts divided by 240 volts = 12.5 amps, so you are OK with a 13 amp plug. Anything above a 3KW oven in the UK should have something meatier than a 13amp plug on it.
Of course, there is nothing to STOP you wiring it to a 45 amp outlet, but the fuse rating for the appliance should be matched to its maximum consumption to protect from faults failing to blow a fuse in a timely manner.
Posted on Jul 19, 2011
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
Have just purchased a hotpoint openspace pyrolytic oven. It has a standard 3 core cable on it stating it is fitted with a sealed unit plug. There is no plug and wires have been bared. Is this normal. Is it...
Jul 19, 2011 | Hotpoint Ovens
Not to sure what wire to use and if I can use a plug
You can use it a 13amp plug if it is just a single built in oven and the total wattage does not exceed 3000 watts..
Anymore than 3000 watts, then it will have to be hard wired into a seperate control unit with 6mm twin and earth cable.
Feb 19, 2011 | Belling Ovens
I am going to install my new mytag oven MEW7530WDS01, can you tell me the Amp. protection required for this oven? it is a 220V
If it is just a single oven then a 13amp fuse is all that is required for the oven.
If you are unsure, then check the rating plate.
If the total amperage does not exceed 3kw, then it is safe to use it with a 13amp fuse., Anymore than 3kw, then it should be hard wired, with a minimum 30 amp fuse for protection.
Feb 12, 2011 | Maytag MEW7530WDS Stainless Steel Electric...
Hard wired or plug in
if i bought a single oven with a three wire cable coming out the back with no plug, which i know is meant to be hard wired, are you saying i could fit a plug to this and plug it into a normal 13amp socket, reason i ask i ahve an oven which has packed in and it plugs into the wall at the back, if i fitted a plug onto the cable from a single oven below 3kw then are you saying i can do this?
Jan 20, 2010 | Ariston Technologies Ovens
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Installing a B1641 oven
Providing it is just a single fan oven on it's own. then it will work fine from a normal 13 amp socket.
If it is a double oven, then it will have to be hard wired into a cooker control switch box, protected with a 30amp circuit trip or fuse.
Please rate my solution to your query.
Thanks.
Feb 19, 2009 | Neff B1641 Single circotherm super...
Wattage for double oven
im getting a indesit fid201 double oven does it have to be hard wired or can it go on a 13amp plug
Feb 14, 2008 | Ovens
Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Nov 04, 2007 | Ovens
Ovens Logo
77 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
