If you look at the gray plastic part at the top, there's this gray nub thing. Slide the tube onto that and your problem is solved.
That clear tubing needs to be carefully reinserted into the drain, hole in the top of the bucket holder.Do it very gingerly, being careful not to kink or twist the tubing. Depending on how long it is, you have have to work it past a bend in the tubing holder.Be careful doing this.
Hope this helps you & thanks for choosing FixYa.
SOURCE: When I take out the
There's a pointy gray nub above the end of the tube. Slide the tube onto that and it should fix the problem.
