Question about Panasonic KX-TG4000B 4-LIne Multi-Handset Cordless Phone System
While on line 1 of my panasonic kxtg4000b the light is on for line 2 incoming call and no ringing is occurring. how do I fix this problem?
Posted by vprddsinc on
5 Related Answers
Anonymous
SOURCE: I HAVE A PANASONIC PHONE
Emeritus,
There are several things to ask yourself.
1. Do you have the manual?
2. Is there any software programming which relates to set ring?
3. Is there a manual switch for ring on/ring off?
4. Will another phone ring when plugged into the same jack?
IF NOT, the red and green wire may be reversed at the jack.
5. Lastly, has this cordless handset ever rang?
Most cordless sets have a volume control from off to loud. I hope this will help you solve your problem.
I
Posted on Feb 25, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
Posted on Sep 04, 2008
Anonymous
  • 211 Answers
SOURCE: Avaya partner 18D phones
No response. closing
Posted on May 09, 2009
consultel1
george peters
  • 860 Answers
SOURCE: some 816 phones won't ring on incoming calls
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Posted on Jun 05, 2010
Dooper
  • 90 Answers
SOURCE: I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP
only 1 handset rings because in default only one extension is allocated as the operator -
you will nedd to enter system programming PROG * # 1234 AND SCROLL THROUGH PROGRAMMING
you will have to find -
group (enter the member you want to ring)
then aim DDI number at this group
or if analogue line then DIL to point to this group
Posted on Nov 13, 2010
2answers
There is now no ring associated with incoming calls on line 3, but otherwise that line functions for both incoming and outgoing calls
http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
page 80,do this first,
25611223-5sp5orn0xnhdqraxk0v0421v-4-0.png then if you want to reset both phone and base,
clear base unit settings to default,
1 Press {MENU}. 2 Scroll to "Initial setting" by pressing {<} or {>}, then press {ENTER}. 3 Scroll to "Initialize base" by pressing {<} or {>}, then press {ENTER}. 4 Scroll to "Clear settings" by pressing {<} or {>}, then press {ENTER}. L The "Clear settings?" screen is displayed. 5 Press {CLEAR}. L Confirmation tone is heard.
clear handset to default,
Press {MENU}. 2 Scroll to "Initial setting" by pressing {V} or {^}, then press . 3 Scroll to "Initialize HS" by pressing {V} or {^}, then press . 4 Scroll to "Clear settings" by pressing {V} or {^}, then press . L The "Clear settings?" screen is displayed. 5 Press . L Confirmation tone is heard.
3helpful
5answers
I have 10 Panasonic KX-T7730 using 8 phone lines. I've confirmed with AT&T that all 8 lines are setup for caller ID. I've confirmed that all 8 extensions have the Caller ID enabled. Two of the
Firstly, you have not indicated which phone system your phones are connected to, e.g. KX-TA824, KX-TDA50 or other, so I'm a little in the dark. That being said, most of the Panasonic Systems only display Caller ID information (CID) to phones that are programmed to "Ring" on the line with the incoming call, and the line button flashes green to show it's ringing... so you must "system program" ringing for the line(s) on each phone. If the CID is not displayed on a particular phone, then that line is likely not programed to ring on that phone (it's light may flash red instead of green). After you "system program" the line to ring, you can still shut off the ringing sound on a phone using the slide switch on the left edge of the phone if you don't want to hear ringing, and this will not interfere with the CID display. Also, on a second note, CID does not display on the first ring coming in from the phone company (TELCO). The CID signal is sent from the TELCO to your system after the first ring has ended, during what would be the silence period that would occur before the second ring, if there was no CID. It is for that reason that most knowledgeable installers program lines with a five second delayed ring; in this way, you don't know the call has arrived until after enough time has passed for your system to receive the CID signal... this is why it seems the CID appears instantly, with an incoming call. Check out the line programming for each line and set it to ring with a 5 second delay. If you don't set up a delay, your phones will ring and if you answer the call immediately, its likely it won't allow the system to receive CID, so no CID will be displayed for that call.
3helpful
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
1 lines is ringing & another is not ringing
Somewhere you should have a programming and operating manual for your phone system. Typically in a Panasonic you turn on CALL WAITING for both Intercom and Outside lines via a code you dial at each phone on the intercom (7311# 7321# for a TA).
This is assuming that the lines are already programmed to ring at the phone.
Carl
2answers
I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP -PBX PHONE SYSTEM WITH PANASONIC PHONES KX-T7633 PHONES.WE HAVE NINE PHONES IN THE OFFICE AND I CAN ONLY GET 1 TO RING ON INCOMMING CALL HOW DO I GET ALL...
In program no (620) enter all the extension nos which you want to ring in group 1. Then in program no (450) enter the floating no of group 1. You will get the floating no in program no (623).
2helpful
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
On a AT&T Partner R4.1 calls, Recv rotary ring xtalk on other cal
So, when line 1 rings in, it makes line and line 2 ring? If so, the riser vendor is a ****. The line is double punched. Call in a good vendor to hit them..
Carl
Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
Lands Phones Logo
Top Panasonic Lands Phones Experts
Ekse
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
