Question about Symphonic ST427FF TV
Hooked up my dvd player and the movie wont show on the tv is there a special channel it needs to be on ?..no Auxilliary channel option for the dvd or vcr players ...need help i dont have the remote control ..Tv is not communicating with the Dvd player..Im stumped please help
Posted by melowayz50 on
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Posted on Sep 13, 2008
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: I have no remote..can't get to Video :(
Try channel 0
Posted on Jan 19, 2009
Anonymous
SOURCE: DVD player hooked up, no auxilliary channel
I also have this ******* problem and apparently there is not solution. So just remember, next time you wanna find the urge to buy a ******* sanyo...dont do it. Sanyo = Bigfoots ****!
Posted on Jul 14, 2009
jhinsincity
Julio Hernandez
  • 616 Answers
SOURCE: I have a symphonic tv that i am hooking a sony dvd
INTERNET
Posted on Jan 12, 2010
Anonymous
  • 7 Answers
SOURCE: I need a code for hooking up a polaroid dvd player
You need the right tv remote code. Try to ger the code here
polaroid tv codes
Posted on May 31, 2010
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
Tv tuner
how about hooked up with dvd player to watch movies it works fine?.then how about the controls like channel up/down and volume button does it works just let me know first.
Oct 15, 2012 | Televison & Video
I have a Toshiba dvd player and all the componeyd are hooked up,right but the,screen for the dvd channel is white with lines and wont show the picture movie what's wrong
You may be using the wrong channel. Is the input the 5-plug component or the 3-plug RCA?
each one will use a different channel, and component will not work in rca and vice-versa.
May 03, 2011 | Westinghouse Televison & Video
May 15, 2009 | Sanyo DS19310 19" TV
My Sharp 42" LC42D85U tv 1 month old no picture or sound
i would take it in and have it repaired while its got a warranty on it...or take it back to the store you got it from and ask them to replace the set.
Feb 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
To connect my dvd player
Check your remote. On my Sentry 2, the magic is the SOURCE button, which allows you to access the AUX (auxilliary) channel. This is what you need to select to view your DVD output.
May 10, 2008 | Zenith C27A24T 27" TV
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Feb 19, 2008 | GE 25GT240 25" TV
Symphonic ST427FF TV Logo
80 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
