SOURCE: Philips Magnavox 20MS3442/17 Green Line
If this is a tube type or crt type. Your vertical circuit has a problem. Could be the vertical IC loose connection on its board. Or the vertical ic itself is faulty. If just resoldering or refluxing of its pins doesn't help check some minor cmponent within vertical circuit. Or the vertical ic is defective already.
If your not inclined on electronics never do the repair itself, nasty voltages might caught you.
SOURCE: What is the code for my remote control on a
What make and model do you have. (remote?)
You can go to:
www.remotecodelist.com
www.tvcodes.com
www.remote-codes.com
SOURCE: I have a magnavox model# 20MS3442/17 that has
purchase a universal remote from walmart not to exspensive and easy to set up
SOURCE: How can i connect my nintendo 64 to a magnavox
N64 is pretty old so RCA connections is about the best your going to get. Not sure where You could pick this up locally since the one end that plugs into the game system is unique to the Nintendo 64 but this it what it looks like and it will run you like 8 bucks on the Net.
