I have two Philips Brilliance 220sw lcd monitors hooked up to my video card but the left hand one makes a 'whining' noise when it displays the video card output. i.e. when the blue 'Philips' logo shows - no sound, when the desktop or applications show - whining noise. Its driving me mad! Especially as i'm trying to write music.... Grr!
Posted by Jason Blake on
NinaE
    President:
  • 3,278 Answers
Hello.
Switch the monitors on your video card to see if the monitor or the video card port is the problem. If the same problem occurs on the left side with a different monitor, the video port is problematic. If the problem switches to the right side, the monitor is problematic.
Or, hook one monitor at a time to test on the right and left sides.
Hope this helps.
Posted on Sep 20, 2011
  • NinaE Sep 21, 2011
    So, what happened ?
Bought a new screen yesterday, and is seems that every letter has i white shade before it.
Go into the setup menu for the video card in your computer and tone down the sharpness control. Watch the monitor when you're doing that so you don't make it out of focus.
Oct 01, 2014 | Philips Brilliance 242G5DJEB 24-Inch...
Coloured lines across the computer
Hook a spare monitor to the video output, if picture okay the LCD panel display will need to be replaced, go to www.ebay.com type make and model of laptop, refine search to screen. But if both show the same symptom it is the video graphics card.
Jun 03, 2012 | IBM ThinkPad T40p 2373 Notebook
I am trying to connect my philips brilliance 170p monitor to my dell laptop.....the monitor keeps saying 'no video input'....help?
After plugging it in, you'll need to actually tell your laptop to use the 2nd display and select an appropriate resolution. Go to display settings, select 2nd display, and select "extend display to this display".
Aug 04, 2011 | Computers & Internet
190 P is connected to the computer hard drive and power supply cables are switched on, but there is no signal showing power to the screen
Well, you need to find out first if it is the computer video card problem or not by trying another monitor with this PC, or try this monitor with another PC before goin any further.
Did it work before? Anyhing was doen to either the monitor or the PC?
Please post back what you find.
Mar 04, 2011 | Philips Brilliance 180P1L (Black) 18 in....
I have a philips brilliance 200w6 lcd moniter that has no sign of power, i have checked all and replaced all capacitors, got power going though all the boards in the back but still no sign of power, no led...
scle193, What happened that you needed to replace electrolytic capacitors? Why ??? Still no sign of power??? Did you pay attention to polarity when replacing the capacitors? Did you document you work with a digital camara to make sure that you could put it back together without having any leftover parts or unconnected cables. Have you measured the dc voltages at the output of the SMPS? Have you checked any and /or all onboard mounted FUSES?? What was the original complaint you had with this monitor? Have you tried to get a service manual or schematic from Philips? Get back to me with info
if you can. lmistyrel @aol.com bye for now. louie12fix
Sep 26, 2009 | Philips Brilliance 200WP7ES - Flat panel...
The picture on the monitor flip 180 degrees how do I flip it back
Operating system of PC?
What brand of video card?
right click on empty part of screen.
left click on properties.
left click on settings.
left click on advanced.
look for the video card tab and left click on it.
left click on Start the "#####" (made of videocard) control panel.
Look in left hand panel for rotate display.
left click rotate display and there should be options to rotate display...
May 04, 2009 | Star Logic 17" LCD Monitor
I have a Philips Brilliance 200W Monitor now about 2 years old. I have been away for a week and the screen had been left switched off on the monitor switch but still connected to the mains and...
Did you check the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor. Try it on another machine and see what it does.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 04, 2008 | Computers & Internet
Monitor hookup
http://www.eserviceinfo.com/downloadsm/4253/philips_107b.html
this is the manual please go through it
this will solve your problem
 good luck.
Oct 17, 2007 | Philips Brilliance 107B 17" CRT Monitor
Computers & Internet Logo
344 people viewed this question
Ekse
Marvin
Marvin
