Question about Hitachi 53FDX20B 53" Rear Projection Television
Image problem with the hitachi projection 50 inche, there is a tinge of green all the time with on the sceen (each side only) some blue doites visible when dark what is the problem
Posted by bout_chant on
Bryon Reed
    New Friend:
    Problem Solver:
  • 16 Answers
Convergence output Ic's and check associated low ohm resisters, replace any that are open.
Posted on Dec 30, 2013
5 Related Answers
Anonymous
  • 4402 Answers
SOURCE: Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
Anonymous
  • 4402 Answers
SOURCE: hitachi 52 projection tv
Anonymous
  • 59 Answers
SOURCE: Green tint on Samsung Television
Hi sbatsch,
Not to worry - this problem is very common with projection TVs and is easily fixed:
The reason for the green shadows (and the resulting wrong colors) is that the three color tubes (red, green, and blue - the three colors of light that combine to form all the other colors) are not lined up exactly - this lining up is known as "convergence." You can fix convergence automatically or, if it doesn't work to your satisfaction, manually. Here's how:
Automatically:
1) Press MENU.
2) Go down to CONVERGENCE (using the up and down arrows)
3) Select it (usually with the left or right arrow)
4) Go down to AUTO and select it - the process should take about a minute.
If this doesn't work, then try manually:
1) MENU
2) CONVERGENCE (as above)
3) Select MANUAL
4) Using the number keys, SELECT, and the arrow keys, adjust the alignment of the different color crosses - the goal is to make them appear white (meaning that the red, blue, and green are exactly aligned on top of one another).
Here's a link to the JVC user manual that will explain the manual convergence adjustment in more detail.
http://resources.jvc.com/Resources/00/00/96/52105ien.pdf
I hope this helps - please let me know if I can be of any further assistance.
Posted on Dec 11, 2008
TONY BIGNELL
  • 147 Answers
SOURCE: 50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Posted on Apr 15, 2009
Anonymous
  • 80 Answers
SOURCE: TV red spot
Your light engine is going bad.
Posted on May 21, 2009
1helpful
Hitachi 51F59A has 3 'lamps', blue, red, & green. No light coming from the blue, both others are lit
don't waste your money go and buy a new smart tv a 50 inch is around 400 and up. Wal-mart, Sam's Club. etc...
I have a 65 inch Hitachi HDTV. There are red,
Sounds like you need to purchase a convergence kit. Instuctions are included
1helpful
I have a 50 inches philips projection tv and the image that is coming is slightly dull than normal . it seems that the the sharpness is kind of reduced
please open back side of your t.v and tack soft clean cotton and clean the guns in side the tv, red/green/blue , just cleane the guns and it will come to the normal picture quality. thanks ikram baig
Image is showing with yellow & red shades
Ur convergence is dead.Must know how to solders?Replaced convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit.Shop will cost u $300 for parts and labors.
7helpful
5answers
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
try this
Hitachi 52 projection tv
Hitachi 53FDX20B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Ekse
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
