Remington MicroScreen DA-307 Electric Shaver Logo
Posted on Sep 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Remington DA 307 shaver motor speed dropped to a slow speed versus the normal high speed needed for a clean shave. What would cause my shaver's motor speed to drop to such a low speed that the shaver barely able to shave facial hair. Thanks Robert
shaveroutlet.com
Level 3:
  • Remington Master 1,652 Answers
  • Posted on Sep 21, 2011
shaveroutlet.com
Remington Master
Level 3:
Answers
1652
Questions
0
Helped
765029
Points
4209
The rechargeable batteries are probably going bad. You can replace them but it is less expensive to replace the whole shaver bottom. This is available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-da307-lower-unit-p-844.html
Take apart remington da 307
This should help: https://www.youtube.com/watch?v=1iE86OI8CaA
How do I clean a Remington Shaver
If micro screen style, pop off the screen and use included brush to clean out all the beard hair. Spray with shaving lube then pop screen back on. That's it!
My Remingtin R856 Wet/Dry Sport is making a high pitch whining sound that it didn't make before. It seems to come from the motor, since it also does it when the blades are not engaged. Sometimes it...
Probably not serious, just needs some lubrication. The shaver is quite a few years old and the grease in the gears and motor shaft has probably dried up. If you disassemble the shaver and lubricate those parts, it should stop the noise
Shaver was running slow and then died. Replaced
Your original symptoms sure sound like dying batteries. Brushes can wear out. Check if it runs better if you change the orientation of the shaver. Does holding it upside down make it work better or worse? If the speed changes, its probably the brushes. You can buy new brushes, but the Norelco repair place will probably give you a hard time since they want to repair it for you so you have to insist. I have made brushes for the shaver by filing down brushes from some other motor, but this is messy and doesn't always work.
1helpful
Shaver has water in it
hello open the swrews of ur shaver and dry if not go to ur neareast shop and ask him to open and dry the water ok bye if it is ok rate me with ur choose
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gene Lawson
Mike Cairns
Mike Cairns
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
