Question about Nikon D60 Digital Camera
I have a Nikon D60 ,I have a problem with my lens ,my lens is infected by fungus so my all pics are looks fogy.I just answer to how to remove from my lens.?
Posted by ompraksh1890 on
neeraj_ece
    New Friend:
I checked with service center for Nikon p100 fungus problem and they said, it can't be clean only replace the lens....
Posted on Mar 19, 2013
Ty Price
    Brigadier General:
  • 11,967 Answers
This is not something you can do....you need to send the lens to a service center for a professional cleaning.
Posted on Sep 20, 2011
How to change playback setting on D60
Download the user manual from Nikon by following this link User Manual D60 Nikon Knowledgebase and look on page 96.
Jan 08, 2013 | Nikon D60 Digital Camera with 18-55mm lens
Why does my Nikon D60 while on auto focus or quick shutter speed either not focus and take the pic or focus and not take pics?
I have a 5D Mark II that has acted up like this. 99% of the time it will reset itself it you power off, remove the lense and allow them to sync up. Try this, it may work for you too!
Apr 22, 2012 | Nikon D60 Digital Camera with 18-55mm lens
Will a Nikon Sigma 70-210 work on my nikon D60??
Assuming the lens has a Nikon mount, then it will fit and work on the D60. Sigma makes lenses for a variety of cameras; a lens with a Canon mount, for example, will not fit onto a Nikon camera. However, the 70-210 is a rather old lens. Unless it specifies "HSM" it will not autofocus on the D60. The D60 does not have an autofocus motor, relying on the lens to have one. Nikon calls such lenses "AF-S" while Sigma designates theirs "HSM".
Feb 03, 2011 | Nikon Sigma 70-210 F4-5.6 55MM AutoFocus...
My shutter is stuck and i sent it to a service centre and they released itand now the shutter is releasing. but when pictures are printed some pictures are half shadowed so i sent it to a Nikon...
A lens cleaning to remove fungus can be quite expensive. If it is a consumer lens or a cheaper lens then often it can be cheaper to buy a used or sometimes even new lens than for a cleaning of fungus.
As for the shutter - it probably needs to be replaced. It is possible it could be repaired, usually replacement is the better option. Different service centers will charge different amount for this.
But often it is worth it vs buying a new camera.
Nov 13, 2010 | Nikon FM10 35mm SLR Camera
Nikon d60 When I try to take a picture with the
That is a problem that has to do with the Flash...make sure your flash settings are not turned on. If the flash can't find an image...it rotates and usually never finds the image. It's reading in a Flash mode.
Mar 25, 2010 | Nikon D60 Digital Camera
Hi, I have a nikon lens that has fungos inside the lens, is there any way to clens it?
Hello. Sadly, the answer is no. You must have the lens repaired by a tech. If the fungus is on the front lens element, trying to remove the lens for cleaning will invite disaster in short order. There are hidden set-screws, grease, precise distances, and sometimes timing positions involved. If the fungus is severe enough, the actual glass element will have to be replaced because fungus can etch itself into the surface! The key to preventing fungus is to NOT store the camera/lenses in a cool, dark, place like a closet or drawer. If you do need to store the system for a longer period, remove all batteries, use a desiccant(the little packet that says DO NOT EAT) which absorbs moisture, and then close up everything in a sealed bag. This keeps any extra moisture from entering the sealed environment of the bag while the desiccant keeps the interior extremely dry.---Hope this helps!---Rick
Oct 02, 2009 | Cameras
D60 won't turn on
Nikon told me to remove battery, remove SD card, remove lens and then hold the shutter button down for 30 seconds. If the Also sometimes the contact between the lens and body is not quite perfect and removing and replacing the lens hleps. If not it has a 1 year warranty, return to them with the exact error message (even if the problem is just intermittant) and they can usually find and fix the problem if the above things do not do the trick. Tonya
Aug 07, 2009 | Nikon D60 Digital Camera
Quantaray 100-300mm Lens for Nikon
Yes the new nikon D60 needs lens with a built in a/f motor. Your lens will go on and work but you will
have to manual foucs
Sep 30, 2008 | Quantaray Zoom 100-300mm f/4.5-6.7 for...
Inserting pics into PowerPoint
2 things. make sure you are not using RAW format for your images and also make sure the pics are not too big. you can set these in the menu. :)
Sep 29, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D60 Digital Camera Logo
119 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Nikon Camera Expert? Answer questions, earn points and help others
