Watches Logo
Posted on Sep 20, 2011
I need a battery for my Locman aluminum case ref 400. Or 488. I can not read the model number because the print is too small and my eyes are too old! I am near Piazza Di Spagna in Rome. Thank you
1 Related Answer
Anonymous
  • Posted on Mar 28, 2010
SOURCE: how do i set the date on a locman ref 487?
  • To set the date you pull out the winding knob to the first stop and turn it either clockwise or counter clockwise to set the date. The second stop, or the stop furthest from the body sets the time.
I am looking for instruction manuel locman aerotica militari
Hello. I think you can find all the necessary instructions for Locman on Google. And lately I started to get involved in computer games. I find them on https://romsify.com/ and then I hang out for a long time. Found a new hobby for myself :)
4answers
Need to activate my new Locman 1974 self winding watch
this website may be helpful to solve your problem
http://www.finewatchmaking.com/
Aug 18, 2008 • Watches
Replace locman battery 130
My watch is locman Nuovo ref .014 ATM and I need battery and new screws to , how I can order those parts please
anderson
10helpful
2answers
How do you change battery on E Howard wrist watch, how does bach come off?
The back does not come off (case is in one piece); it's the bezel -- the metal rim that holds the front glass crystal.
There is a small notch in the rim of the bezel (on mine, this aligned with the 'lower left' lug on the case around 7:00 on the face). Be careful as there is an O-ring to waterproof the watch, and this notch goes right into the groove where that O-ring is located. Use a case knife or similar stiff but fairly thin-edge blade to pop the bezel off (it snaps off). Then gently remove the outer plastic ring, noting carefully how the notches are aligned.
The inner module now can be lifted carefully out - the two 'pushers' will not fall out of the case when you do this. The battery is a 3V lithium CR2025, and you will need a fairly small straight-blade jeweler's or optician's style screwdriver to remove the one screw that holds down the battery bracket - it may be tempting to bend this out of the way to change the battery, but please resist that temptation...
Put the module back in the base, put the ring back over the dial plate, and carefully snap the bezel back in place with its notch aligned as you found it. You might want to check and/or lubricate the O-ring as you do this.
Instructions for initializing the movement are printed inside the case: they list the switch for the 'recessed' button as A, and the pusher as B. In case you didn't note them before closing the case: to reset:
1) push A once. (Display will read "SET"
2) Push A until hands are exactly on 12:00 (and display reads "12"
3) Push B once to start reception
You then follow the standard procedure of putting the watch in a window facing Fort Collins, Colorado, until it picks up the time signal and synchronizes itself.
If you need more assistance with the physical module, there is contact information on it from its manufacturer:
[email protected]
Model number on my module is AR600 WWVB (37.5mm)
Initial manual recharge
I looked at their site which was particularly unhelpful and can only suggest that you locate their nearest dealer by going to their site "http://www.locman.it/rivenditori_eng.asp" and ask them to help you.
How do i set the date on a locman ref 487?
Top Locman Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Locman Watch Expert? Answer questions, earn points and help others
