Computers & Internet Logo
Posted on Sep 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i switch my computer on, windows profession window appears and say press ctrl+alt_delete to begin, I do that but nothing happens. My laptop i'm using is a Dell Latitude D630
Sanath Kumar V
Level 3:
  • Master 684 Answers
  • Posted on Sep 20, 2011
Sanath Kumar V
Master
Level 3:
Answers
684
Questions
Helped
165052
Points
1521
Step 1 - Remove non bootable media
Remove any floppy disks, CD's or USB sticks from your computer and restart.
If NTLDR is missing error appears again, Do the Next Step.
Ensure you boot the system from the CD. The system will then boot into the Windows XP Setup.
At the welcome screen press 'R' to enter the Recovery Console
At the recovery console, select your Windows XP installation and enter your Administrator password if requested
At the command prompt issue the following commands and press ENTER after each command:
fixboot
fixmbr
Remove your Windows XP CD and restart the computer
If the NTLDR is missing error appears again after reboot, Try the Next Step.
It is sometimes necessary to run or re-run the Windows XP Setup repair process
If it did not solve your issue re-insert your Windows XP CD and run Windows Setup again
Good Luck!!!!
tip
Easy shortcuts with windows
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
on Oct 23, 2010 • Computers & Internet
2helpful
Cant see option to log out/sign out on facebook from Lenovo g50 laptop
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Describe your sony vaio PCG-C1VRX/K Problem: O/S not found...cannot enable usb/cd use to fix/load new O/S
What do I do if the message "Operating system not found" appears when my computer starts, and why won't Windows start? ? Make sure the computer does not have a "non-bootable" floppy disk in the floppy disk drive (if applicable). ? If a non-bootable floppy disk is in the drive: 1. Remove the floppy disk. 2. Restart the computer and confirm that the Microsoft® Windows® operating system starts properly. ? If Windows still does not start, follow these steps to initialize the BIOS: 1. If there is a disk in the floppy disk drive, then remove it. 2. Turn off the computer. 3. Remove any peripheral devices connected to the computer. 4. Restart the computer. Page 1475. Press F2 when the VAIO logo appears. The BIOS Setup window appears. 6. Press the Right Arrow key to select the Exit menu. 7. Press the Down Arrow key to select Get Default Values. The message Load default values for all SETUP items appears. 8. Press Enter. The Setup Confirmation window appears. 9. Select Yes, and press Enter. 10. Select Exit (Save Changes), and press Enter. The Setup Confirmation window appears again. 11. Select Yes, and press Enter. The computer restarts. What do I do if my computer stops responding? Why can't I turn off my computer? It is best to turn off your computer using the Turn Off Computer option on the Microsoft® Windows® Start menu, located on the taskbar. Using other methods, including those listed below, may result in loss of unsaved data. ? Click Start on the Windows® taskbar, select Turn Off Computer, and then click Turn Off. ? If your computer does not turn off, press the Ctrl+Alt+Delete keys simultaneously. When the Windows Task Manager dialog box appears, click Turn Off from the Shut Down menu. ? If your computer still does not turn off, press and hold the power button or slide and hold the power switch until the computer turns off. ? If your computer stops responding while playing a CD or DVD, press the Ctrl+Alt+Delete keys simultaneously. You can turn off the computer from the Windows Task Manager. Pressing the Ctrl+Alt+Delete keys simultaneously or turning off the computer with the power button or switch may cause loss of data. ? Remove the AC adapter and battery.
tip
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore...
Windows XP HELP
  • Windows key + R = Run menu
  • cmd = Command Prompt
    iexplore + "web address" = Internet Explorer
    compmgmt.msc = Computer Management
  • Windows key + E = Explorer
  • ALT + Tab = Switch between windows
    ALT, Space, X = Maximize window
    CTRL + Shift + Esc = Task Manager
    Windows key + Break = System properties
    Windows key + F = Search
    Windows key + D = Hide/Display all windows
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
  • Keyboard Shortcuts
  • [Alt] and [Esc] Switch between running applications
    [Alt] and letter Select menu item by underlined letter
    [Ctrl] and [Esc] Open Program Menu
    [Ctrl] and [F4] Close active document or group windows (does not work with some applications)
    [Alt] and [F4] Quit active application or close current window
    Ctrl] Lft., Rt. arrow Move cursor forward or back one word
    Ctrl] Up, Down arrow Move cursor forward or back one paragraph
    [F1] Open Help for active application
    Windows+M Minimize all open windows
    Shift+Windows+M Undo minimize all open windows
    Windows+F1 Open Windows Help
    Windows+Tab Cycle through the Taskbar buttons
    Windows+Break Open the System Properties dialog box
    explorer shortcuts
    END....... Display the bottom of the active window.
    HOME....... Display the top of the active window.
  • Type the following commands in your Run Box (Windows Key + R) or Start Run
  • devmgmt.msc = Device Manager
    msinfo32 = System Information
    cleanmgr = Disk Cleanup
    ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    excel = Microsoft Excel (If Installed)
    msaccess = Microsoft Access (If Installed)
    powerpnt = Microsoft PowerPoint (If Installed)
    winword = Microsoft Word (If Installed)
    frontpg = Microsoft FrontPage (If Installed)
    notepad = Notepad
    wordpad = WordPad
    calc = Calculator
    mspaint = Microsoft Paint
    wmplayer = Windows Media Player
    control = Opens the Control Panel
  • Internetbrowser
  • type in u're adress "google", then press [Right CTRL] and [Enter]
    add www. and .com to word and go to it
  • For Windows XP:
  • Copy. CTRL+C
    Cut. CTRL+X
    Paste. CTRL+V
    Undo. CTRL+Z
    Delete. DELETE
    Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE
    Copy selected item. CTRL while dragging an item
    Rename selected item. F2
    Move the insertion point to the beginning of the previous paragraph. CTRL+UP
    Select all. CTRL+A
    Search for a file or folder. F3
    View properties for the selected item. ALT+ENTER
    Close the active item, or quit the active program. ALT+F4
    Opens the shortcut menu for the active window. ALT+SPACEBAR
    Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4
    Refresh the active window. F5
    Cancel the current task. ESC
    on Oct 12, 2010 • Computers & Internet
    tip
    CTRL+C (Copy) CTRL+X (Cut) CTRL+V (Paste) CTRL+Z (Undo) DELETE (Delete)...
    CTRL+V (Paste)
    CTRL+Z (Undo)
    DELETE (Delete)
    CTRL+A (Select all)
    Dialog Box Keyboard Shortcuts
    CTRL+TAB (Move forward through the tabs)
    CTRL+SHIFT+TAB (Move backward through the tabs)
    TAB (Move forward through the options)
    SHIFT+TAB (Move backward through the options)
    ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
    ENTER (Perform the command for the active option or button)
    SPACEBAR (Select or clear the check box if the active option is a check box)
    Arrow keys (Select a button if the active option is a group of option buttons)
    F1 key (Display Help)
    F4 key (Display the items in the active list)
    BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
    Windows Logo (Display or hide the Start menu)
    Windows Logo+BREAK (Display the System Properties dialog box)
    Windows Logo+D (Display the desktop)
    Windows Logo+M (Minimize all of the windows)
    Windows Logo+SHIFT+M (Restore the minimized windows)
    Windows Logo+E (Open My Computer)
    Windows Logo+F (Search for a file or a folder)
    CTRL+Windows Logo+F (Search for computers)
    Windows Logo+F1 (Display Windows Help)
    Windows Logo+ L (Lock the keyboard)
    Windows Logo+R (Open the Run dialog box)
    Windows Logo+U (Open Utility Manager)
    Accessibility Keyboard Shortcuts
    Right SHIFT for eight seconds (Switch FilterKeys either on or off)
    Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
    Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
    SHIFT five times (Switch the StickyKeys either on or off)
    NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
    Windows Logo +U (Open Utility Manager)
    Windows Explorer Keyboard Shortcuts
    END (Display the bottom of the active window)
    HOME (Display the top of the active window)
    NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
    NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
    NUM LOCK+Minus sign (-) (Collapse the selected folder)
    LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
    RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
    PAGE UP (Move up one screen at a time)
    PAGE DOWN (Move down one screen at a time)
    HOME (Move to the beginning of the line)
    END (Move to the end of the line)
    CTRL+HOME (Move to the first character)
    CTRL+END (Move to the last character)
    SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
    Microsoft Management Console (MMC) Main Window Keyboard Shortcuts
    CTRL+O (Open a saved console)
    CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
    Remote Desktop Connection Navigation
    CTRL+ALT+END (Open the Microsoft Windows NT Security dialog box)
    ALT+PAGE UP (Switch between programs from left to right)
    ALT+PAGE DOWN (Switch between programs from right to left)
    ALT+INSERT (Cycle through the programs in most recently used order)
    ALT+HOME (Display the Start menu)
    F5 key (Update the content of all console windows)
    ALT+SPACEBAR (Display the MMC window menu)
    ALT+F4 (Close the console)
    ALT+V (Display the View menu)
    ALT+F (Display the File menu)
    ALT+O (Display the Favorites menu)
    MMC Console Window Keyboard Shortcuts
    CTRL+P (Print the current page or active pane)
    ALT+Minus sign (-) (Display the window menu for the active console window)
    SHIFT+F10 (Display the Action shortcut menu for the selected item)
    F1 key (Open the Help topic, if any, for the selected item)
    CTRL+F10 (Maximize the active console window)
    CTRL+F5 (Restore the active console window)
    ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
    CTRL+ALT+BREAK (Switch the client computer between a window and a full screen)
    ALT+DELETE (Display the Windows menu)
    CTRL+ALT+Minus sign (-) (Place a snapshot of the active window in the client on the Terminal server clipboard and provide the same functionality as pressing PRINT SCREEN on a local computer.)
    CTRL+ALT+Plus sign (+) (Place a snapshot of the entire client window area on the Terminal server clipboard and provide the same functionality as pressing ALT+PRINT SCREEN on a local computer.)
    Microsoft Internet Explorer Navigation
    CTRL+I (Open the Favorites bar)
    CTRL+L (Open the Open dialog box)
    CTRL+N (Start another instance of the browser with the same Web address)
    CTRL+O (Open the Open dialog box, the same as CTRL+L)
    CTRL+P (Open the Print dialog box)
    CTRL+R (Update the current Web page)
    CTRL+B (Open the Organize Favorites dialog box)
    CTRL+E (Open the Search bar)
    CTRL+H (Open the History bar)
    on Jul 25, 2010 • Computers & Internet
    2helpful
    Guide
    General keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • CTRL+C (Copy)
    • CTRL+X (Cut)
    • CTRL+V (Paste)
    • CTRL+Z (Undo)
    • DELETE (Delete)
    Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
    • CTRL+TAB (Move forward through the tabs)
    • CTRL+SHIFT+TAB (Move backward through the tabs)
    • TAB (Move forward through the options)
    • SHIFT+TAB (Move backward through the options)
    • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
    • ENTER (Perform the command for the active option or button)
    • SPACEBAR (Select or clear the check box if the active option is a check box)
    • Arrow keys (Select a button if the active option is a group of option buttons)
    • F1 key (Display Help)
    • F4 key (Display the items in the active list)
    • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
    Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • Windows Logo (Display or hide the Start menu)
    • Windows Logo+BREAK (Display the System Properties dialog box)
    • Windows Logo+D (Display the desktop)
    • Windows Logo+M (Minimize all of the windows)
    • Windows Logo+SHIFT+M (Restore the minimized windows)
    • Windows Logo+E (Open My Computer)
    • Windows Logo+F (Search for a file or a folder)
    • CTRL+Windows Logo+F (Search for computers)
    • Windows Logo+F1 (Display Windows Help)
    • Windows Logo+ L (Lock the keyboard)
    • Windows Logo+R (Open the Run dialog box)
    • Windows Logo+U (Open Utility Manager)
    Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
    • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
    • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
    • SHIFT five times (Switch the StickyKeys either on or off)
    • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
    • Windows Logo +U (Open Utility Manager)
    Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • END (Display the bottom of the active window)
    • HOME (Display the top of the active window)
    • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
    • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
    • NUM LOCK+Minus sign (-) (Collapse the selected folder)
    • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
    • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
    Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
    • RIGHT ARROW (Move to the right or to the beginning of the next line)
    • LEFT ARROW (Move to the left or to the end of the previous line)
    • UP ARROW (Move up one row)
    • DOWN ARROW (Move down one row)
    • PAGE UP (Move up one screen at a time)
    • PAGE DOWN (Move down one screen at a time)
    • HOME (Move to the beginning of the line)
    • END (Move to the end of the line)
    • CTRL+HOME (Move to the first character)
    • CTRL+END (Move to the last character)
    • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
    Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • CTRL+O (Open a saved console)
    • CTRL+N (Open a new console)
    • CTRL+S (Save the open console)
    • CTRL+M (Add or remove a console item)
    • CTRL+W (Open a new window)
    • F5 key (Update the content of all console windows)
    • ALT+SPACEBAR (Display the MMC window menu)
    • ALT+F4 (Close the console)
    • ALT+A (Display the Action menu)
    • ALT+V (Display the View menu)
    • ALT+F (Display the File menu)
    • ALT+O (Display the Favorites menu)
    MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • CTRL+P (Print the current page or active pane)
    • ALT+Minus sign (-) (Display the window menu for the active console window)
    • SHIFT+F10 (Display the Action shortcut menu for the selected item)
    • F1 key (Open the Help topic, if any, for the selected item)
    • CTRL+F10 (Maximize the active console window)
    • CTRL+F5 (Restore the active console window)
    • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
    • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
    tip
    Windows General Keyboard shortcuts
    CTRL+V (Paste)
    CTRL+Z (Undo)
    DELETE (Delete)
    CTRL+A (Select all)
    tip
    CTRL+C (Copy)
    CTRL+X (Cut)
    CTRL+V (Paste)
    CTRL+Z (Undo)
    DELETE (Delete)
    CTRL+A (Select all)
    Microsoft Natural Keyboard Shortcuts
    Shortcut Keys for Character Map
    CTRL+F (Start the Find utility)
    CTRL+W (Close the current window)
    on Mar 10, 2010 • Computers & Internet
    tip
    KEYBOARD SHORTCUTS ON WINDOWS XP
    General keyboard shortcuts For Windows Xp
    • CTRL+C (Copy)
    • CTRL+X (Cut)
    • CTRL+V (Paste)
    • CTRL+Z (Undo)
    • DELETE (Delete)
    on Dec 03, 2009 • Computers & Internet
    tip
    General Keyboard Shortcuts, General Keyboard Shortcuts General Keyboard...
    CTRL+C (Copy)
    CTRL+X (Cut)
    CTRL+V (Paste)
    CTRL+Z (Undo)
    DELETE (Delete)
    CTRL+A (Select all)
    Grand Canyon Tech
    Grand Canyon Tech
