Bad pressurestat or bad heating element. PS feeds power to heating element, heating the machine til its up to pressure, which then turns the pressure stat off. If either of the two pieces are bad neither will work properly.
Could also be the machine is overfilled which causes the machine to take longer to heat up.
SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
SOURCE: AEG ESPRESSO MACHINE
With the machine cold (or hot if you have the right implement and can keep your hands away from the steam) I would try to insert something like a pin or a small length of bicycle brake cable up the frother tube and see if you can free what probably is a plug of solid mik in the end of the frother. Sounds like a blockage, it may suddenly blast out steam if you free it and you have the valve open so watch out. If it's not that then I would take the valve apart, especially if the machine is making the right noises. I'm not farmiliar with AEG machines though.
SOURCE: Steam wand works, but no water for espresso
I have found that I have to remove the group valve assembly about once every 1 or 2 months to clean out the .030" to .040" opening in the valve body. The manual gives instructions on how to do this. It becomes clogged with a thick paste like substance.
SOURCE: Hamilton Beach Espresso Machine
I have had similar issues with my 40729.
Assuming that when you turn on the steam switch, the steam light goes on and then off when up to temp:
I have resolved this by filling my steaming pitcher with boiling water, remove the end-cap from the frothing wand and soak the end of the steam pipe in the hot water for several minutes. Then fire up the steam and blow it out. if the obstruction is more serious, then you may need to unplug the machine and run a thin and stiff wire ( like a guitar string ) up through the wand to break up the clog.
This unit uses one heater for both the extraction and the steam, so if you are getting extraction then the heater is good. You may also have either:
SOURCE: Starbuck's Barista steam wand leak
DPcurry is right. You may have to plug it in to get a "feel" for which way and to what degree to rotate the shaft, but works like a charm.
