Kenmore 63652 Microwave Oven Logo
Posted on Sep 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After I entred the desired minutes, when I press START it does not work. And if I press the ADD MINUTES, it is not working. Please can you tell me any solution. Can this problem be due to not cleaning the gresae filter or the charcoal filter?
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 65 Answers
  • Posted on Sep 20, 2011
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
65
Questions
0
Helped
21078
Points
120
HELLO.
The steps to the solution are as follows.
Off the microwave oven and it.
Then plug the microwave oven and power on the microwave.
Allow the microwave oven to load itself.
Then reset the timing program.
Test the microwave for normal operation.
NOTE:if the problem persist,cleaning the microwave is the next solution.Below is the solution to cleaning the microwave oven.
  • Remove oven racks and soak them in soapy water.
  • Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • Let the oven do its work; it will heat for several hours, charring off baked-on foods.
Thanks.
How to set clock on air fry microwave by galanz
For the Galanz 1.2 cu. ft. ToastWave, GTWHG12BKSA10, you need to press and hold the Clock/Timer pad for 3+ seconds. If needed, press again to switch between 12 and 24 hour clock options. Then rotate the dial until the correct hour is displayed. Press one of the following: the dial, Start or Clock/Timer to save the current hour. Rotate the dial to set the current minutes. Again, press the dial, Start or Clock/Timer to save the current minutes. To exit the clock setting mode, press Stop/Cancel.
HomeDepot has the manual for this microwave/air fryer on the product page: https://www.homedepot.com/p/Galanz-1-2-cu-ft-Countertop-ToastWave-4-in-1-Convection-Oven-Air-Fry-Toaster-Oven-Microwave-in-Black-GTWHG12BKSA10/310997710 . The current link to this manual is https://images.homedepot-static.com/catalog/pdfimages/e8/e87f4420-a777-460f-901f-faa70016a38f.pdf . See page 9 for the directions to set the clock.
I hope this helps. Please add a comment with the model number of your microwave/air fryer if the above steps don't work.
2answers
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    No microwave problem. I have a micro 21 by raytheon pan. Please tell me how much water, vegetables and time to cook them. I don't have a instruction book.
    I found an instruction booklet. For most veggies (1/2 lb) steam for 10 minutes using 3/4 cup water. Add 5 minutes steaming time for frozen. 1 whole cauliflower is 15 minutes & 1 cup water
    72helpful
    Round soft key OXO Timer I need to change the clock time their model # is 1061978
    Operating functions:
    To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
    To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
    When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
    This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
    Buttons aren't working. It says Press Start and when you do it either doesn't work or add second to the cook time, and never cooks
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for about 5 minutes.
    If it still does not work, you likely have a failed membrane keypad.
    We would need your full model number to help you further or give an estimate.
    Feel free to contact me directly (and please remind me of your full model number) for more information & help.
    William E. "Ed" Miller, AS-EET
    [email protected]
    http://www.microwavedisplay.com
    2helpful
    4answers
    I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
    The owner's manual is here. On page 10 we find:
    COOKING IN ONE STAGE
    1. Press the POWER button; the Microwave and High
    Cook indicators will light and “PL 10” will light in the
    display.
    2. Press the POWER button different times to set the
    desired power; the display will show the percentage
    you chose. If selecting power level 70%-10%, the
    Low Cook indicator will light instead of the High
    Cook indicator.
    3. Press number keys to set the desired cooking time.
    OPERATION(CONTINUED)
    4. Press the START/+30SEC. button to start cooking;
    the Microwave and one of the Cook indicators will
    blink and the display will countdown the remaining
    cooking time in minutes and seconds. It will beep
    five times when cooking is completed.
    1helpful
    2answers
    No numbered touch pad for use setting clock
    I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
    If that doesn;t work, press STOP / CLEAR then try the above again.
    Let us know if it does not work.
    1helpful
    Call engineer and E-10 on display on amana commercial URFS518S Micro wave oven could you please tell what the fault is and how i can cure it. Regards.
    E10:
    An attempt has been made to program the oven for more time than allowed.
    1. Press STOP/RESET pad.
    NOTE: Maximum cooking time is 60 minutes except when cooking with full
    power (100%). In case of full power (100%), maximum cooking time is 20
    minutes.
    If that doesn't work, leave it unplugged for maybe an hour then try again.
    An owner's manual that may work for you is here.
    Whirlpool RMC275PD microwave won't start
    I would first suggest unplugging the oven for a few minutes to give it a reset. On Whirlpool brand microwaves, you will hear a series of beeps when you hit START if one of the following is true: - the control panel is not programmed correctly - the door is not shut - there is a problem with the door latch system - there is a problem with the control panel If you do not have your owner's manual, you can download it here: http://www.whirlpool.com/custserv/literature_search_results.jsp?searchTerm=RMC275PD#literror It doesn't sound like the control panel is locked. When the control panel lock is activated, you will see "Loc" and a lock symbol in the display and only the clock, timer, and oven light will operate. If that does not solve the problem, then you have oneof the other problems as listed above. If you need further help, please reply / add a comment here.
    Top Kenmore Microwave Ovens Experts
    ZJ Limited
    ZJ Limited
    Paul Carew
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
