SOURCE: the light comes on for a second then goes out
try taking the battery out of the laptop and connect it directly to power outlet. Then start the laptop. If this works then its your battery. If this doesn't then it could be the Operating System itself or BIOS if an update was done on the BIOS lately.
SOURCE: Can I use a micro sd card from my nokia on my acer...
If your acer has an microSD card slot, you may use that provided that you have a microSD card adapter slot wherein you will insert the microSD card to the adapter. Then check if the adapter will fit the microSD card slot. IF it is not , then your acer has the SD card slot , not the microSD card...
SOURCE: acer extensa 5235 change windows 7 to vista,, it
Please find the relevant driver to download here...
Acer Driver download
SOURCE: Model; Acer Extensa 5235
the best way is that u should update its software ie-formatt it by scanning the important data
SOURCE: i need to completly reboot
Your note book is virus affected.
Try to system restore in earlier date. Follow the step
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
>start>program>accessories>system
tools >system restore >set earlier date. If you have the strong
virus you can not do that, then you should better to copy your data if
necessary
follow step>set your hard disk in another computer .before install be ensure that .another pc is well condition.
>show hidden folder can see all system file >can open task
manager>run type ms config >enter, it will be open windows>run
type gpedit.msc> enter, it will be show.>run type regedit enter
,it will be open .think your another pc run in ok condition. Then type
gpedit.msc and hit >administrative templates>system>turn off
auto play>select enable>click down arrow >select all drives.
SET IT FROM BOOTH SIDE BECAUSE THERE ARE TWO SIDES >Go tools> 1
folder options>views>check on show hidden files and folders>2
check off hide extension >3 check off hide protected.
Now auto
run program off. you can see and delete easily all the hidden
unnecessary file .auto run file. Placed virus affected hard disk in this
pc.explore drive select autorun/recycler/system volume information by
dragging and delete it. Don't do the system drive for ensure r click
on my computer >manage>disk management>identify system drive
>and system drive letter>
Now You can copy your file and store
in another drive which formatted emediate.And you can format drive
one after one and transfer all the file to the formatted drive .Switch
off the pc and put your pc again and install your os and set the pc same
way Then type gpedit.msc and hit >administrative
templates>system>turn off auto play>select enable>click down
If you did not have the cd rom , you should create a bootable flash. follow the link.
http://articles.techrepublic.com.com/5100-22_11-5928902.html
Good by
http://www.fixya.com/support/t7665080-dell_inspiron_1501s_card
