SOURCE: RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
Cheers.
SOURCE: cooktop red light is staying on
The red light is on as a safety to let you know the surface is hot. When the light goes out the surface will be safe to touch with out getting a bad burn.
Please rate 4 thumbs for the free answer.
SOURCE: have whirlpool glass cooktop,, the
This is usually one of the switches has failed. You will need to uninstall and disassemble to acess the switches. They are easy to check and replace. Here is a link that should help http://appliancehelponline.com/infiniteswitchvideo.html You can also enter your model # for diagrams and illustrations of your specific model.
