Question about Lenovo ThinkPad Z61t Notebook
How do i change the screen from vertical display to horizontal
Posted by hoseamoore48 on
Eury Satorre
  • 957 Answers
The IBM ThinkPad Z61t computer runs the Windows operating system. Normally, Windows is displayed on a monitor in a manner that makes it easy to read. If you want to change the screen display configuration (from vertical to horizontal), modify the screen display properties in Windows itself. This process causes the computer to rotate the image displayed on the screen by 90, 180 or 270 degrees, depending on the setting you choose.
1.Right-click on an empty portion of the Windows desktop on the Z61t.
2.Click "Properties."
3.Click "Display."
4.Click "Change display settings."
5.Click the "Orientation" drop-down window. Select the "Landscape" option to make the screen display items in a horizontal manner.
Posted on Sep 19, 2011
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
We have an orion 2501B TV.no vertical display
The vertical Ic maybe are damaged and some of the electrolitic capacitors near by
Top screen has horizontal and vertical lines
The only solution is to replace this top screen.
Buy.com has the top screen for $20 Bucks!
Search Top Screen Replacement Display on there.. Hopes this helps.
1helpful
2answers
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
TV screen dislay partial horizontal beam
you had a problem on vertical section of your tv, if can fix it ,change the 100/50 volts capisitor on .vertical section or else all capasitors in vertical section
Screen displaying a thin white very bright horizontal line.... plz help
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Lenovo ThinkPad Z61t Notebook Logo
Top Lenovo Computers & Internet Experts
Ekse
Abhinandan  Patil
Abhinandan Patil
Steve Sweetleaf
Steve Sweetleaf
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
