Question about Yamaha RX-V1500 Receiver
I have a rx-v1500 hooked to my Hd tv and cable and dvd player.The remote does not emit any signal.It is daed. Replaced the batteries. Same thing. Ordered a new remote from Yamaha. Still no signal. Yamaha said it could be the sensor in receiver is no longer working? Is that possible? Is it easily repaired and what would be the cost?
Posted by tendizzyfing on
David Dunn
    Brigadier General:
  • 8,546 Answers
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Posted on Sep 20, 2011
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
I have a DVD and a HD cable box going through my Yamaha RX-2400. Things worked great for past 6 months but recently started getting flickering picture and eventually picture was gone. TV says it is...
I'd investigate the intervening video-carrying cables.
Consider whether you actually NEED to route video through the receiver in the first place. Is all that extra cable and 2 extra interconnections actually doing any good? Apparently not.
In my rig, I run high-end video only to my TV and high-end audio only to my receiver. No problemos.
Feb 12, 2011 | Yamaha RX-V2400 Receiver
My hd cable box works great in all of the video in connections on the tv, but my dvd player, hd camera do not work when I plug them in, the picture is like it is scrambled, but if I plug the cable box in...
Are you connecting these devices to the ColorStream inputs?
If so you will need to set the output settings on the DVD player or your camera to 480i. You have an HD capable TV but it is old technology and is not capable of handling the signal levels produced by HD equipment these days.
Look at the menu options on your equipment and most of them have the ability to put out the lower level signal or just hook them up using the standard yellow/red/white inputs. Hope this helped.
Good Luck..
Dec 10, 2009 | Toshiba 36HF72 36" TV
Can not hook my hdtv phillips tv to my dvd and
That is because your player does not support an HD signal and cannot complete the signal from one system the other.
Nov 28, 2009 | Pioneer DV-563A DVD Player
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Mar 15, 2009 | Yamaha RX-V3800 Receiver
Hooking my DVD player up to my HD converter
connect as follows,,,
converter-->VCR-->TV
DVD-->VCR-->TV
watch DVD as before, when VCR is off, the converter will show up on the TV
Feb 19, 2009 | Televison & Video
Losing digital picture with HD TV
First, hide the remotes so that the TV cannot "see" it. If the problem goes away, it's the remote. Other than that, it sounds as if the receiver is faulty...accordianman
Nov 02, 2008 | Yamaha RX-V861 Receiver
Yamaha RX-V1500 Receiver Logo
114 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
