Question about Panasonic AG-188 Camcorder
How do I connect my panasonic vhs 188 camcorder to a dvd recorder?
Posted by dmlumas2010 on
Scott Bailey
    President:
  • 720 Answers
On these old models of VHS camcorder, I recall they have either RCA outputs, or BNC connectors which will require a BNC adaptor (to convert to RCA).
Using a 3RCA lead, connect the camcorder to the video (and audio) inputs of your DVD recorder.
Posted on Sep 19, 2011
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Jan 31, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
I would like to convert a VHS tape to DVD. I have (1) the Sony Handycam Digital 8 DCR TRV310, (2) Panasonic VCR, and (3) Macbook Pro with iMovie. I don't know much about the digital camera's ability to...
I think you are expecting camera to covert VCR analog video-audio signal into digital so it can be record in Macbook?
Camcorder will not do this job and you need to hookup VCR with DVD Recorder to burn DVD of VHS tape.
Jan 07, 2009 | Sony Handycam DCR-TRV310 Digital Camcorder
Transfer DVD to VHS
You must use the input select button on the vcr remote to turn on the jacks on the front or back of the vcr. If you need a remote, call the customer service number on the vcr to see if it is still available.
Oct 08, 2008 | Sansui VHF6010 VHS VCR
Power save function
Do you put a tape in when you try to record or do you connect to a DVD / VCR so that it records onto the DVD or VHS?
If this is how you do it, then I will recommend you use a mini DV tape instead.
Hope this helps.
Osei71
Sep 10, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Convert NTSC VHS video tapes to DVD PAL
If you do not have an adaptor to play the tapes to a standard VHS viseo player, you can use the camera as the player by connecting the AV out to a DVD recorder. There are hundreds of models in the market, and do not worry if it is NTSC or PAL because 99% of DVD recorder accepts both.
May 23, 2007 | Panasonic PV-GS150 Mini DV Digital...
Panasonic AG-188 Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
