Question about Gateway Computers & Internet
Gateway laptop died. Several times it appeared to reboot only to go black and go off. No fan or lights. How can I fix this myself?
Posted by rmshaw4 on
John Porter
    Scholar:
  • 96 Answers
Does it show that it is charging from the charging light/power supply? Is there any life left in the battery? is the charger charging the battery? the batteries dont last in laptops usually about a year before the go bad and have to be replaced, Is the charger working? The chargers go faulty all the time, The little plug that plugs into the laptop goes faulty and is a very common fault and doesnt charge/power the laptop, The only thing you can try is another power supply of the same name/model/output voltage and current with the same small plug and polarity or another battery of the same type/model, If you can do this and it doesnt cure your fault it needs looked at by a technician, Hope this helps, If you need more assistance let me know,
Posted on Sep 19, 2011
My Gateway nv5378u Laptop Fan makes a horrible noise when turning on.
fan is hit something or worn out take it and have it replace before you burn the processor up .good luck
Jan 16, 2013 | Gateway NV5378u Notebook
I have a gateway ms2285 and it was working fine i turned it off the next day i tried to turn it on and nothing happen the blue power light came on and the battery light came on but the screen was black and...
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 28, 2012 | Gateway Computers & Internet
Gateway 450ROG, will not start. Red DVD/CD ROM
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Mar 31, 2010 | Gateway 450ROG Notebook
Screen stays black when booting up on Gateway laptop
there is a inverter in lcd that makes shinely, white .
it looks like inverter issue. need to get service.
May 29, 2009 | Acer Aspire One PC Notebook
Screen on my laptop will not work. Black screen.
Test if it works on external monitor. If it does, then turn the computer on, remove the battery, then reinsert the battery. That little trick has worked several times for me and my customers. If the external monitor does NOT work, then you probably have a bad video chip in the computer's motherboard.... by the time you fix it, you could almost by a new machine.
May 25, 2009 | Gateway M305CRV Notebook
Laptop LCD Screen won't come on and computer keeps rebooting
Try checking the inverter, if that is intermittent, it could short the system and cause the symptoms you are describing.
Apr 03, 2009 | Gateway 7330GZ Notebook
LG LS55 LAPTOP DISPLAY SCREEN BLANK/BLACK
I think your laptop might be stuck in SUSPEND mode. Try unplugging the power and removing the battery and waiting five minutes, and then plugging it back in. If this does not work, try holding down the power button for ten seconds at a time and rebooting.
Good Luck...
Nov 29, 2007 | LG LW20-EV Notebook
Laptop shutdown monitor shut to soon / stuck in sleep mode
the problem is the power off sensor ... this is a sensor to shut the monitor of if u close the lid (monitor) so it seems like that this sensor is still on the closed status so try to find it then see if it's a mechanical try to move it with your hand and if it's an electrical try to but a light on it .... if it work please rate me!
Sep 11, 2006 | Gateway (2500068) Motherboard
Computers & Internet Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
