Question about Pulsar Watches
My mother has a fifteen year old Pulsar Y480-5730 that doesn't run anymore. Any recommendations?
Posted by kab8224 on
Lisa Christine
    Scholar:
  • 62 Answers
Did you check the watch battery? Pulsar watches run a long time! If a new battery does not start it up you can take a can of air and just squirt a little in the area where the battery goes (very gently) to blow out any dirt then install the battery and put back on. If it is still not working you need to take it to your local jewelry store to have an estimate for repair, usually 60.00 to 80.00. I hope this helps!
Posted on Sep 19, 2011
Pulsar solar watch repair, stopped running
They have a rechargeable battery in them,you'll have to go to jeweler or a watch repair store.the battery is not cheap!!! I had my wifes fixed a few years ago the battery cost $68.00,but she likes the watch so it was worth it.
Jan 17, 2013 | Pulsar Watches
Need owners manual for Pulsar PQ2001 Digital Watch
I don't know if the offer is still good after two years, but take a look here.If you just want to set the time, look here.
Apr 10, 2012 | Watches
I don't know whether the offer is still good after two years, but take a look at this thread.If you just need to know how to set the time, look here.
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
My pulsar watch (maybe 7 years old)runs intermittently. It runs most of the time I wear it and stops when I take it off. I had it cleaned. Cleaning didn't seem to help much.
is it battery or automatic or kinetic. first have battery checked if this still does not solve prob ask repairer for movement exchange instead of service as this way you get a new engine...if its automatic a service should have worked as pulsr use seiko movements wich are very good if its kinetic it needs a new capasitor as these last about 5yrs before the need to replace or attempted recharge.
Mar 23, 2010 | Watches
Purchased a new pulsar chrono as a gift, the battery was dead, since found out low charge batteries are placed in new watches to check functions but they recommend the battery be change. Problem is,...
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
Dec 26, 2009 | Pulsar Watches
Cover on 20 year old Pulsar pocket watch won't
Most likely the spring which locates at he cover hinge pin is either bent or broken.
Aug 20, 2009 | Watches
Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
Jan 12, 2009 | Watches
Pulsar watch band
I have a Pulsar watch and on the expandable band, the casing fell off and can't get it replaced unless we take off a link...To me this was too much trouble, time and expense...I won't buy another Pulsar! Too bad cause I thought it was a beautiful watch.
Jun 15, 2008 | Pulsar Watches
Pulsar Mens Wrist Watch
I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
Jan 30, 2007 | Pulsar PXF216 Wrist Watch
Watches Logo
251 people viewed this question
Top Pulsar Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
ray gallant
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
