Washing Machines Logo
Posted on Sep 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine does not complete wash cycle. Gets to rinse than stops. Does not rinse or release water. When I manually move the dial to spin, nothing happens?
Dean Burns
Level 2:
  • Expert 45 Answers
  • Posted on Sep 18, 2011
Dean Burns
Expert
Level 2:
Answers
45
Questions
Helped
10945
Points
117
You need to check the pump it sounds like you have something in it .Clean out the pump and the unit will finish the cycle if the pump is not burnt out.
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
5helpful
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
33helpful
2answers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
I also need the answer...
where is the lint trap located
2answers
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Top Washing Machines Experts
john h
