Question about KitchenAid Ovens
Just got error code "fe02"
Posted by thisissuewhi on
Gene Meier
  • 2,341 Answers
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . GENE
Posted on Sep 18, 2011
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven just beeps when i turn it on
Hit stop clear then reprogram oven If that won't work unplug for a short time plug back in and see if this works. It found a fault code in the oven control and if you can't reset it. You will have to order a new one. Go to managemylife.com if you need to download manual
Dec 09, 2011 | Kenmore Ovens
What does error code "F-1"
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Sep 09, 2011 | Ovens
The General Electric under the counter oven is beeping and only stops when I push the Clear/Off button. Then it resumes beeping 1-2 minutes later. Also "F7" appears to the left of the time...
The F7 error code means that a key on the touchpad has shorted and the touchpad needs to be replaced... sometimes it's a electronic anaomily, since you have pushed Clear/off and the F7 returns it surly means that touchpad is bad.
GENE
Sep 09, 2011 | General Electric Ovens
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
Our JTP15 beeps and displays F7 is there a reset for it?
Yes, you will need to press the stop/cancel button, this will clear the error code and the display.
Nov 14, 2009 | GE JTP15 Electric Single Oven
Ovens Logo
748 people viewed this question
Top KitchenAid Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
