Question about Hotpoint Washing Machines
Hot point ultima 1600 dose my hot point ultima 1600 need a cold feed even tho it has a hot feed as i use my cold for my other washer
Posted by rosst220988 on
Reg Woolley
  • 99 Answers
Yes because it wont rinse
Posted on Sep 18, 2011
Our whirlpool washer uses hot water when set on cold? Any suggestions as to why this occurs.
Hello George Stewart,
The most OBVIOUS guess would be the cold water FEED is connected to the WRONG (hot water) side...
Try reversing those hoses from the wall.
Hope this helps...
Deep analysis will require a make & model number.
Carnac the Magnificent
Sep 06, 2018 | Whirlpool Washing Machines
Does Hotpoint Ultima WF860 need both hot and cold pipes?
Only if you need to have both hot and cold water wash options.
Jan 23, 2013 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA WD71..WHEN THE MACHINE IS SWITCHED ON TO A WASH PROGRAM IT WORKS FINE FILLING WITH HOT WATER THEN STARTS ITS CYCLE. WHEN THE MACHINE REACHES THE RINSE1 CYCLE IT STOPS WITH A E10 ERROR CODE....
Following is pre-typed, saves time - in your case just refer to 'cold' please ;-0)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 16, 2011 | Hotpoint Ultima WF860 Front Load Washer
Can i run my ultima wma74 off the cold feed only?
Hi Naomi from retired Englishman in SW France,
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
John C
Jul 07, 2011 | Hotpoint WMA74 Front Load Washer
Water supply is on,no kinks on hose,checked filter,but wmd940 display says no water supply..thanks..
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
Thanks and good luck!
John C
May 15, 2011 | Hotpoint Ultima WF860 Front Load Washer
Can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN washing machine run off a cold fill only
The simple answer is yes, via a Y piece if it is a hot and cold fill model
The fitting is available from B&Q, or a plumbers merchants
Aug 13, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint ultima tumble drier condenser has F 10 error code
Error code F10 means common feed of heater or thermostat open circuit.
You need to test the thermostats and the heater element for continuity.
You need a multimeter to do this, assuming you know how to use a meter,then set it on the ohms range for continuity, remove one wire from each stat, and test with meter across terminals of stats,
You should get FSD if stats are o/k.
If you don't, then you need to replace both stats, even if only one is faulty.
It is unlikely to be the element that is faulty, as they rarely fail.
Plz rate my solution.
Thanks
Jan 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA WF860
image_bubbleanswer_04.gif I recently had the same problem with my Hotpoint Ultima WF860P and after some investigations, I found a disconnected tube linked to the pressure switch beneath the top cover was the cause of the problem. In short, this tube forces air to the pressure switch and cuts off the valve feeds.
Andrew Algar - Brighton
Feb 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Hotpoint Washing Machines Experts
James Hehling
James Hehling
Level 1 Expert
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
