Sony Handycam DCR-PC9E Mini DV Digital Camcorder Logo
A
Anonymous Posted on Jun 22, 2017
Hi got Sony DCR-PC9E,tape ran out while recording,replaced with new tape yellow condensation symbol flashing+ C:21.00 on screen. Tried new tape-insert&close carriage instead of pulling carriage into body it pops back open again.Camera had'nt been anywhere damp but put open into airing cupboard overnight just in case-no difference,any ideas its been brilliant camera,always used best quality tapes,sony or TDK and not been abused? Thanx Simon
4 Related Answers
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Camera Case will not close
I solved my Sony Camera problem by throwing the camera in the trash and vowing never to purchase a Sony Camera again. When I saw many other people posting the same problem on the internet, I came to the conclusion this is a major problem with Sony Cameras.
Anonymous
  • 10594 Answers
  • Posted on Sep 02, 2008
SOURCE: Sony Digital video Camera Recorder DCR-PC6E/PC9E
hello..
did you received my message?
Clarification Request by welcomejee, posted on Sep 01, 2008 please mention what dvd recorder you have or you want to transfer movie files on PC hard disk.
Anonymous
  • 320 Answers
  • Posted on Oct 20, 2008
SOURCE: Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Anonymous
  • 338 Answers
  • Posted on Jun 13, 2010
SOURCE: My Sony Handycam DCR-PC9E mini DV Digital
This is a simple case of the Bat going dead, it does look from what I read that the Sony batteries do not seem to stand up long these days, I am hearing of this daily on the Mini Cameras, where my old faithful 8mm camera bat is 8 years old and as good as new.
Sony DCR-VX1000 won't leave standby mode
Please double check that your camera has well-charged power source and has enough memory or capacity to record new data. Since the camera was sold starting around 1995, this would be a tape. If there is no more tape to record, then you would run into the issue that you've mentioned above. But there are other possibilities as well.
Thank you.
Clean the head
I have a DCR-100, which is basically the same camera, and had the same problem after I hadn't used it for about 5 years. After running a cleaning tape through it four times it became much clearer, but sometimes, reviewing my equally old tapes the pixellation/distortion reappeared spasmodically. I ran the tape at FF to the end, and then back again. Seemed to fix it. I think after a long period of disuse the recording heads oxidise and it takes quite a bit to clean them. As to why loosening up the tape works - no idea!
2helpful
2answers
2helpful
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
1helpful
2answers
hello..
Sony DCR-TRV145E Digital 8 camcorder - won't play or record.
Fortunately they are still making 8mm camcorders usually running less the $200 to replace. It could be more cost effective to get a new model for that price as well. I couldn't record on my Sony 8mm camcorder anymore after five years of use and over 100 tapes that I had recorded. It's plays back but that's about it.
1helpful
3answers
Sony DCR PC110e camcorder
My problem with the DCR PC110E Sony camcorder is being unable to download my videos from tape to the PC or laptop through the firewire connector. Have you ever had this problem?
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
