SOURCE: 1000w emerson microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
The fact that the turntable stopped running is an even stronger indication that you have a door switch related problem.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Emerson MW8119SBM microwave. Use popcorn button.
Try clearing the microwave before pressing the popcorn button again.
SOURCE: looking for a Emerson Microwave
go on line to the company & see if u can't purchase manual, or write the company. Company name & often address or location is located on plate that model # is on. Hope this helps.
SOURCE: Microwave Oven EM-804T
When I opened up the microwave cover, noticed that the door latch mechanism was worn and not holding up the interlock switch. A thick piece of tape on the worn piece of plastic and microwave was back to working (I had symptom of the timer counting down without the microwave turning on)
