Kenmore 6.6 cu. ft. / 187 liter Chest Freezer 13601 Logo
Michael EauClaire Posted on Jan 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power is ok and you can hear compressor or whatever click on and then after 10-15 seconds it shuts off again. It will do that periodically after shutting off for several minutes. It's like it wants to start but can't get going. Thanks, Michael Kenmore 183.13601300. Unit is about 6 years old.
Ron Lake
Level 2:
  • Expert 66 Answers
  • Posted on Jan 03, 2018
Ron Lake
Expert
Level 2:
Answers
66
Questions
Helped
11470
Points
122
Replace the motor capacitor.
5 Related Answers
Anonymous
  • 770 Answers
  • Posted on Feb 12, 2008
SOURCE: Compressor Stops on Kenmore Chest Freezer
The thermostat needs to be replaced part # 216230400 it is $59.51 at www.sears.com (parts) or it is $52.45 at www.apdepot.com this will fix ya.... both will ship direct to you. If you have to leave you can unplug unit and jumper out the thermostat 2 wires plug back in. This will make the unit run 24/7 until you get the part but it is better than losing the food
Anonymous
  • 161 Answers
  • Posted on Jun 30, 2008
SOURCE: FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
Anonymous
  • 9 Answers
  • Posted on Nov 12, 2008
SOURCE: Kenmore Upright Freezer compressor running 6 seconds every minute
Usually the compressor runs pretty warm anyway. However if you think it's too hot I would start with the condenser coils located either under the unit or on occasion they are located on the back. The air flow across these coils as well as the airflow around the compressor must be maintained. I forgot to ask if the condenser fan is running. Check and make sure that the Fan is running and the air flow is good. Also, When you transported the unit did you move it standing vertically like it normally stands or did you lay it on its side. If you transported the unit on its side you must wait a minimum of 24 to 48 hours prior to start up or the unit could be ruined permanently. The refrigerant has to be utilized through the compressor as a gas. If the unit is on its side liquid refrigerant could be introduced into the compressor and can cause permanent damage. If this is the case I recommend that you turn the unit off at once and wait the 36 hours for the Refrigerant to settle then try it again. This transportation rule applies for any appliance That uses refrigerant, Air Conditioners etc. These units are not that hard to diagnose. The only other item that is usually a problem is the defrost timer. It is not very expensive and can also cause some of the same symptoms that you are eluding to. The defrost timer allows the freezer to periodically shut down to prevent the buildup of frost or ice on he evaporator coils and on the inside the unit. If it is defective, then the unit will either run all the time and cause the evaporator coils to freeze up or will not allow the compressor to switch on and it will not freeze like it should.
kachbibi1
Bill Dickerson
  • 979 Answers
  • Posted on Feb 17, 2009
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
buddymcl777
Bruce McLeod
  • 67 Answers
  • Posted on May 01, 2009
SOURCE: Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Not cooling
If you hear a hum then a click, that is the compressor short cycling. Put your hand on the compressor in the back, if it is very hot(don't burn yourself) then the compressor is dead and will need to be replaced. If the compressor is cold and not running, check for power through the t-stat and to the freezer. If there is power to the t-stat but not through it then replace the t-stat. If there is power through then there is a good chance the compressor is dead.
Apr 12, 2014 • Freezers
Have magic chef mccf5wbx freezer compressor runs but shuts off in 15 seconds
Check condensor not clogged up, fan working etc. If all ok, try new capacitor and relay. If all else fails, replace freezer (compressor replacement is costly)
1helpful
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
2answers
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
2helpful
Kenmore Chest Freezer Model number 1987191852 has started to defrost own its own. Compressor starts and shuts down after appx 2 seconds. Has this unit reached the end? is it cost effective to repair?
Good day,
That short cycle you hear, is the compressor trying to start, and can't.
It is possible one of the start components has failed. Under a cover on the side of the compressor are either 3 or 2 components.
The start relay, the protective overload and on some models a start/run capacitor. These components can be removed by pulling them off of the pins of the compressor.
Most appliance parts houses will be glad to test them for you. Replace any that test bad.
If all test O.K. then it is an internal problem with the compressor itself, which would take the services of a trained tech and pretty pricey.
I have recently unplugged my upright to clean it out. Upon plugging it back in, I have noticed it will not work! It makes a small buzzing sound like it is starting then ''clicks' off ???
The clicking sound you hear is the protective overload mounted to the compressor, shutting the power off to the compressor because it will not start. Two possibilities.
1. One or more of the starting components has failed. The starting components are A. The start relay, B. The start/run capacitor(some models have them, some don't), C. The overload which is the device you hear clicking. You can pull these parts off the compressor and take them to an appliance parts house. They are usually happy to test them.
2. The compressor has failed internally and needs replaced.
3. Parts houses sell what are called "hard start kits" but that is an iffy proposition. Most appliance techs carry them for testing purposes to see if they can get a balky compressor to start, but are sold to the consumer with the understanding that it may or may not give the machine additional life.
NOTE: If this appliance is under 5 years of age, don't do anything, but call the selling dealer, because the compressor is still under warranty. You'll pay if start components need replaced but you will maintain the balance of your warranty.
1helpful
Kenmore freezer deforsted suddenly. Comes on
compressor relay is probably going out...also check the plug in to the wall. A intermittant contact is a matter of following the source to the compressor. start at the plug and through the temp sensor/ t-stat defrost control and down to the compressor. but ususlly the compressor relay is the culprit.
Oct 25, 2009 • Freezers
1helpful
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
