Question about RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater
How do you calibrate heater.The temperature on the heater does not match the wall temp
Posted by captaingrant on
With CT87K. Temperature set doesnt match actual temp by 4-5 degrees
On some you can calibrate,or it may be location where mounted
Apr 06, 2018 | Heating & Cooling
Dcs oven wos130 wont reach set temperature on bake
Good afternoon Steve!
The answer may depend a bit on what you mean by 'stops heating'.
  • One interpretation could be 'the heating shuts off, and the oven goes back toward room temperature
  • The other would be that it heats up, but it heats to a certain temp and then stays there. it's just not as hot as it's supposed to be.
If it's the former, that sounds like something is overheating and an interlock is engaging because it's interpreted as 'I'm too hot where I shouldn't be, and I should shut off before I cause a fire. I'd leave that to a better trained service tech.
If it's the latter, then it'll depend on how low it is. If it's way low, then there's a couple possibilities:
  1. The heater element is defective, and even at the full current draw the oven can run, it can't get any hotter than that upper temp. This would mean replacing the element.
  2. The temperature sensor in the oven is defective or mis-mounted. There should be a temp sensor inside the oven cavity. if it's disconnected, or, say, bent out of place and much nearer the bake element then it should be, then the heat coming direct off of the element may be fooling it into thinking the oven is hotter than it really is. this could mean replacing the temp sensor, or just re-mounting it to proper position.
If it's just a bit low, then there could just be a calibration problem. If you look at the manual here
DCS WOS 127 Use And Care Manual Child Safety User Option you can see how to adjust the calibration up or down in temperature to, hopefully, match the oven thermometer you're trying to use as a check.
Hope this helps!
Good Luck
D
Nov 18, 2015 | DCS Wot-130 30" Wide Single Electric Wall...
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 | Pool & Spa
Freezer temp cycles above freezing
If you have a frost free refrigerator then temp jumps as you discribe are somewhat normal during a defrost cycle. However it sound like your defrost temp may be getting too high. There is a limit thermostat on the freezer coils that keep the defrost temp from getting too high. The part is called a (defrost termination thermostat) and is a round disk about 1 to 1.5 inch in diameter clipped to the top of the freezer coils with 2 wires coming out of it. When cold, it allows power to the defrost heaters. At around 35/40 degrees it opens and shuts off power to the heater. 35/40 degrees sounds high for a freezer temp but that is behind the wall and only for a short time. Yours may be staying on too long or out of temp calibration needing replaced.
Mar 20, 2015 | Refrigerators
Lasko 5141 - I set the temp to hold @ 68 degrees at night but it seems to ignore the setting and gets into the high 70's. This is with the rotation switch on if that makes a difference. Any Help ? Thanks
Remember it is always colder at the floor level, the heater is pretty close to temp when it is above 40 degrees outside, but as the temperature gets colder outside so does the temperature at the floor level in your house because heat rises.
I use my house furnace thermostat mounted half way up the wall as a guide, When the temp outside is in the teens, I have seen as much difference between the floor temp on the heater and the wall to be 4-6 degrees different. So this means as the tempurature outside drops you need to regulate the thermostat on the heater downward to compensate for the colder floor temperatures.
Jan 10, 2011 | Lasko 5141 Ceramic Electric Heater
Have pentair easy touch controls just installed new water temp sensor. spa is 88 degrees but master temp heater shuts off because it reads 104. what should i check? the thermistor/
If the Easy Touch is reading the correct temperature, but the heater is not - you need to double check the temperature of the pool water with a standard pool thermometer.
Other things to consider:
1) The water is traveling too slowly through the heater. If the water is heating too quickly, then it will shut it off. If it takes a while for this to occur, then this would not be the issue.
2) Thermostat/thermistor is incorrectly reading the temperature of the water prematurely shutting the system down.
Make sure you really are checking the temperature of the water and matching this temperature up with one of the two readings that you are getting. Don't just take the word of the displays on either unit.
Dec 10, 2010 | Pentair Mastertemp Heater
Oven Control indication (temperature) and actual oven temperature do not match. Is there an adjustment? Vulcan Commercial Gas Range
needs calibrated. put oven thermometer in oven, turn on oven. adjust dial to temp on thermometer by loosening nut behind dial, then replace dial, turn to temp, re-tighten nut
Oct 26, 2009 | Kitchen Ranges
I think the oven needs calibrated, because the temperature isn't getting hot enough. It is a u nit it the wall seperate from the stove top
You can only calibrate the temps about 20 degrees. If it isn't getting close to the temp you set it for, you probably have a faulty oven sensor and need to replace it. They usually run around $50-$90, and are easy to replace.
Oct 04, 2009 | Ovens
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater Logo
389 people viewed this question
Top RTO Pool & Spa Experts
john h
Kardoc
Bill Boyd
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
