Question about Samsung Refrigerators
My Samsung RS21 fridge freezer has a temperature of 19 degrees on the fridge part. The freezer part is working OK.I have seen Samsung "repair kits" for sale at over 100GBP - do I need to buy one of these or can I repair it without? Thanks!
D. Floyd Kolb
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 18, 2011
My temp on the fridge keeps on rising to 19 degrees but freezer temp ok
Are you talking about 19 degrees Fahrenheit? The normal temperature for the refrigerator section should be 38?, and the freezer should be at 0?, both in Fahrenheit.
Mar 06, 2015 | Refrigerators
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
My samsung rs21 fridge freezer not making the ice
maybe worth a look at this
samsung diy repairs video guide
some usefull info on samsung fridge freezers various models
Aug 05, 2010 | Freezers
SAMSUNG RS21 AMERICAN FRIDGE FREEZER SOUNDS LIKE A GENERATOR RATHER THAN A FRIDGE AND NOT SHOWING CORRECT TEMPERATURE ON READINGS. FOOD BARELY FROZEN AT TIMES BUT FRIDGE PART SEEMS OK. ANY IDEA'S?
Ring samsung up because this is a common fault in that make. I had the same problem, They should do something depending on when it was purchased ( 2005-2006 i think it was) it was on watchdog.
Nov 12, 2009 | Refrigerators
Samsung Quattro-Cooling RM255LABP Freezer at +20F
orrixcreek i have the same problem. how do you go into the samsung diagnostic? i pressed different buttons at the same time and they're giving me gibberish i dont understand. which specific buttons to press and what exactly do the codes mean? i called samsung and they told me the fridge was probably in "demo mode" that is used on the sales floor and they had me pressed the two left buttons for 6 seconds and a bleep occurred and the LCD went dim. it really didnt fix the problem.
Mar 26, 2009 | Samsung Refrigerators
Fridge not cold enough
-Did you increase the temperature control knob to the higher number ?
-If not then do so. Increase to higher see what it'll do.
-If you already did to any number but still not cold then a New One
Good luck
Mai
Dec 19, 2017 | Samsung Refrigerators
Refrigerators Logo
450 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
