Question about Timex T5K018 Ironman Triathlon 30 Lap Flix Watch
I have a Timex Ironman watch 30 Lap Flix. The "set/recall" button, "indiglo" button, and "stop/reset" buttons will not move. I was having problems with the "stop/reset" button and thought the battery was low. The battery was replaced. Now, the button doesn't work at all. I am unable to set the time on my watch. I am unable to get the stopwatch to stop timing or reset for my next run.
Posted by swgriffin2 on
5 Related Answers
Anonymous
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
Posted on Jan 16, 2008
Anonymous
SOURCE: Timex flix watch
Hello
For some reason, the sound for the alarm and hourly chime is muted. Is there something I can do or is watch defective?
Posted on Jul 02, 2008
Anonymous
SOURCE: i want to know how
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
Posted on Jan 12, 2009
Anonymous
  • 98 Answers
SOURCE: The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Posted on Jan 09, 2010
Anonymous
SOURCE: Timex Sleek stopped beeping when I replaced the battery
I had this problem. I simply flipped the metal plate on the back 180 degrees.
I noticed on the inside of the metal plate a pad about the size of the battery, and guessed from the other notes that this must perform some kind of insulating function. Furthermore, the writing on the outside of the metal plate was not oriented "up"... that is if I was holding the watch in front of me like I was reading it, the writing on the back plate was upside down. Both of these clues led me to believe that the plate had been re-installed wrong. Flipping it around fixed (restored) the beep.
Posted on Feb 07, 2010
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Indigo light doesn't work
It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
Oct 02, 2012 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
My timex ironman 30 lap flix will not move to the chrono mode
From the time mode, just press mode button once and the word "chrono" will appear.
Jul 22, 2011 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Is there a way to stop the alarm beep on every hour.
press and hold the start button along with the reset button for a few seconds.
May 10, 2011 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
I just need online instructions to use the lap timer on my Women's Timex Ironman Triathlon watch. I'm not sure of the model, but I think it's a 50-lap, and it's small. The 4 buttons on the side...
Here is the link that can help you set up your watch. Also here is the All list of timex watch downloadable instruction.
I hope this can help you resolve your issue.
Thank you for choosing Fixya
Mar 06, 2011 | Ironman Timex T5B721 Sports 50 Lap...
I LOST MY MANUAL AND NEED TO FIND A NEW ON FOR THE TIMEX T5J993
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
May 18, 2010 | Timex Ironman Triathlon 100 Lap Flix...
Unable to set indiglo
I take it that you haven't got any instructions for your watch.
manual download"
Feb 15, 2010 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How do I get my indiglo timex watch off military time?
If it is the five button type I have (there are several) you hold "SET" until a field starts flashing. Then hit "MODE" until you see "24-HR" in the display. Hit "LAP/RESET" once and it should display "12-HR". Hit set again and you are done. Also note that timex has all manuals available online for free,searchable by the "module number" you can find on the back plate of your watch. Hope this helps.
Nov 06, 2009 | Timex Ironman Triathlon 30 Lap Shock Watch...
How can i recall multiple laps during a run?
The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
Sep 17, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Timex Watch
While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
Press the mode or bottom left button until the hour digits start to flash.
Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
Mar 09, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
Timex T5K018 Ironman Triathlon 30 Lap Flix Watch Logo
177 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
MrFixitSTTL
Are you a Timex Watch Expert? Answer questions, earn points and help others
