Question about Sherwood RX-5502 Receiver
It looks like this is a common problem with a lot of the Sherwood Receivers. I've had the same problem with my R-125RDS for a while now. Finally hit on solution today by replacing a power transistor. The transistor in question is not on the power amp board but instead screwed to the chassis and wired to the mainboard. I believe it is part of the output short protection circuit. In my case the component was a 2SD2059 (silicon NPN 100V,5A) replaced by equivalent 2SD1407. The transistor seems to run pretty warm so I guess this is why they ultimately fail after a few years.
Posted on Oct 27, 2011
Jul 08, 2017 | Sony Audio Players & Recorders
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
Feb 24, 2012 | Sony MDS-JE330 Mini Disc Player
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Jan 10, 2011 | Harman Kardon HK 3370 Receiver
Nov 16, 2009 | Denon AVR-485 Receiver
Apr 20, 2008 | Audio Players & Recorders
Jun 18, 2006 | Denon AVR-1706 Receiver
May 22, 2014 | Sherwood RX-5502 Receiver
Nov 30, 2012 | Sherwood RX-5502 Receiver
671 people viewed this question
